20 Most Recent
Desa International Remington 12 Electric Chain Saw Questions & Answers
I have a 16 inch chain saw and want to buy a new
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
6/5/2010 11:43:53 PM •
Desa...
Answered
on Jun 05, 2010
Clippper just stopped working
Check for spark. You can also spray some carb cleaner into the engine through the carb and if it runs for a second then it's a carb issue (not getting fuel).
6/21/2014 3:04:45 AM •
Desa...
Answered
on Jun 21, 2014
My 300 utility seems to flood out everytime I try
the needle is not seating with the float which is causing the carburetor to flood. either the needle is not attached to the float(some snap into a plastic groove, others have a spring) or the float is bad. Hope this helps Tim
5/29/2011 12:48:58 PM •
Desa...
Answered
on May 29, 2011
I have a Remington Pole
The RemingtonPower (no longer in production) name has been purchased by MTD. PartsFor.com is the current supplier but parts are very limited, we are not affiliated in any way. 1-800-446-1446 is the number they list. Good Luck.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
• Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
• Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
• Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
• Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
PartsFor.com
http://www.partsfor.com/
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
9/1/2010 8:23:34 PM •
Desa...
Answered
on Sep 01, 2010
Need part for a remington pole saw
Hello Bill;
I am not sure which part you need, you can identify it here and check availability.
Remington.com
- Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
- Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
- Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
- Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If NLA above try the pn here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Are you aware Remington is no longer in production?
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
4/18/2010 7:44:16 PM •
Desa...
Answered
on Apr 18, 2010
Please specify the chain (091375-02S) for the 16
I hope no expert will do as you ask. I will not! I will provide the necessary links and information so YOU can make an informed decision based on what you are given.
Replace Desa with Remington. The EL-8 is not listed, I think if you do a careful inspection of your saw you will find a model number 107624* or 170625* (*matters not). Both of these numbers input below provide the same 3 choices on the following table.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
The above results are for an original or equivalent 16" bar. Only you can determine your level of expertise,how much risk you are willing to assume and choose one of part numbers listed. Once you make your choice the Oregon part number can easily be converted to other chain manufacturers (if your local outlet does not handle Oregon). I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
3/23/2010 5:23:01 PM •
Desa...
Answered
on Mar 23, 2010
