20 Most Recent I30 Latch & actuator assembly - front door right right hand Questions & Answers
Send us additional details.
I30 Latch &... | Answered on Oct 17, 2013
looks like it's hard to get..
why don't u try online
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
Hyundai Vehicle... | Answered on Jan 28, 2019
Hi, My 2012 Cadillac SRX did the same thing to me last year. I replaced the battery in the remote and it fixed the problem. The old battery wasn't strong enough to trigger the proximity sensor on the car. Click on link below.
I hope that will fix yours. HYUNDAI 5WY8740 EN Factory OEM KEY FOB Keyless Entry Remote Alarm Replace
Hyundai Vehicle... | Answered on Jun 26, 2017
Vents are vacuum actuated. check all vacuum lines for cracks or broken
Hyundai Vehicle... | Answered on Oct 09, 2014
Need to have the passenger side air control sensor Checked it is most likely stuck in the last position probably air condition..Hope this helps..good luck..
Hyundai Vehicle... | Answered on Oct 03, 2014
Try tightening but be careful it can break..if sill leaking replace it..any auto parts store carry or can order them.not a bug job..good luck..
you gotta drain the oil then drop the oil pan clean old gasket off and oil replace the gasket and reinstall oil pan put oil back in and after checking the oil level or changing oil you are ready to go
Hyundai Vehicle... | Answered on Sep 09, 2014
I think you can try to use GDS VCI Diagnostic Tool to diagnose it, Then you can found the problem.
V15 GDS VCI Diagnostic Tool for Hyundai & Kia From http://www.careucar.com/wholesale/gds-vci-diagnostic-tool-for-hyundai-kia.html.
GDS VCI Diagnostic Tool is an advanced service system that provides comprehensive coverage for all Hyundai vehicles including all Hybrid cars. GDS provides complete diagnostics, analysis and reprogramming capabilities as well as a huge library of technical, service and repair information. And now buy it, you can get NEW kia GDS software free.
Hyundai Vehicle... | Answered on Aug 19, 2014
Have you diagnosed the car for error codes? Upon reading your question I first thought about the HT leads anp plugs. You replaced those. Next step is to suspect dirty (clogged) fuel injectors. Pour a whole bottle of a good fuel injector fluid into almos empty fuel tank. Then add ONLY 2 gallons (8 liters) of fuel. Drive car around like "you stole it". Try to floor it or fully accelarate in 2nd gear as mech as you can, revvin ebgine above 4000 rpms.
If there was any dirt, varnish or clog in any injector, this procedure should fix it in a day or two.
Still do get an error code diagnosis as soon as possible. You may be surprised about what sometimes comes up.
Hyundai Vehicle... | Answered on Jul 19, 2014
It is inside the fuel tank. It is one of a three part assemby device that goes inside gasoline yank. This assembly is composed by the fuel filter, fuel pump and fuel level gauge sending unit.
It is serviceable ONLY by qualified mechanics under very specific safety conditions.
Engine Coolant Temperature Circuit Malfunction
Possible causes
- Low engine coolant level
- Faulty Engine Coolant Temperature (ECT) sensor
- Faulty engine coolant thermostat
- Engine Coolant Temperature (ECT) sensor harness is open or shorted
- Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
Hyundai Vehicle... | Answered on May 26, 2014
Air leak somewhere or the Air flow sensor is faulty.
Hyundai Vehicle... | Answered on Jan 06, 2014
have you changed the plug leads. or the ds pack some engines have leads or a dispack. dispack the seals can go and cause arking. leads weak leads will sort out in them self and moving them about can reconect them. if they have gone hard they should be changed as that means they are brital.
Hyundai Vehicle... | Answered on Oct 18, 2013
Did you bleed the air out it's just like the brake sys it has a bleed valve to get the air out
Hyundai Vehicle... | Answered on May 17, 2013
The Veloster may or, may not have a manufacturer installed security system. However, what the salesman is trying to sell you is an aftermarket vehicle security system at an inflated price. The vast majority of new car dealers sell aftermarket alarms and remote starters that are installed by an outside company that has a contract with the dealership. These same systems are available at various shops at retail price. The dealership talks you into buying these products by telling you that if you buy it from someone else that your manufacturer warranty will be voided. This is not true. Read magnusen-moss warranty act. I know this because I was the in house installer at several new car dealerships, installing alarms. remote starters, dvd, back up sensors, navigation systems, stereos, etc. for over seven years.
Now, with that being said, not all retail aftermarket shop are the same. Do your research. Read what others have to say about these companies before making a decision to have them install something on your nw vehicle.
Hyundai Vehicle... | Answered on Jan 27, 2013
cylinder 1 is the one closest to the timing belt and fan belt
Hyundai Vehicle... | Answered on Dec 11, 2012
I30 Latch & actuator assembly - front door right right hand Logo
1 questions posted
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Vehicle Parts & Accessories
Most Popular Question
repair hyundai door looks
  • Vehicle Parts & Accessories
