20 Most Recent Jacuzzi Fuzion Whirlpool Questions & Answers
3answers
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
11/20/2022 2:15:44 AM • Jacuzzi Fuzion... • Answered on Nov 20, 2022
When i push the start button, nothing happens. The motor has power, but does not switch on.
Air Switch Repair It sounds like you have a bad air switch located in your motor. The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub. This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. US Parts Center
3/17/2014 9:19:51 PM • Jacuzzi Fuzion... • Answered on Mar 17, 2014
I just installed a Jacuzzi
should of primed it first ?
1/30/2011 10:06:04 PM • Jacuzzi Fuzion... • Answered on Jan 30, 2011
How do i find out the different type of jacuzzi
Look for a plumbing wholesale distributor in your town with a show room. They have catalogs and can find any plumbing fixture or part that you will need.
3/26/2024 7:54:07 AM • Jacuzzi Home • Answered on Mar 26, 2024
The on off light in my Jacuzzi whirlpool bath keeps flashing
The flashing on/off light in a Jacuzzi whirlpool bath may indicate an issue with the control system, and it's important to address the problem to ensure the proper functioning and safety of the whirlpool bath. Here are some general steps you can take to troubleshoot the issue: 1. Check the Power Supply: - Ensure that the whirlpool bath is receiving power. Verify that the circuit breaker for the whirlpool bath is not tripped, and check for any loose or disconnected power cords. 2. Inspect the Control Panel: - Examine the control panel for any visible issues, such as loose or damaged wires, connectors, or buttons. Ensure that there is no water or moisture present in the control panel area. 3. Reset the System: - Some whirlpool baths have a reset function. Turn off the power to the unit, wait for a few minutes, and then turn it back on. This can sometimes reset the control system. 4. Refer to the User Manual: - Check the user manual that came with your Jacuzzi whirlpool bath for specific information on troubleshooting and resetting the control system. The manual may provide insights into the meaning of the flashing light and how to address it. 5. Contact Jacuzzi Customer Support: - If the issue persists and you cannot find a resolution through the manual, contact Jacuzzi customer support or the manufacturer for assistance. They may be able to provide guidance on how to troubleshoot and resolve the issue. 6. Professional Inspection: - If you're not comfortable or able to identify and fix the issue, it's advisable to seek assistance from a qualified professional or a technician experienced in Jacuzzi whirlpool bath systems. They can perform a thorough inspection and diagnose and repair any electrical or control system problems. It's essential to prioritize safety and follow proper procedures when dealing with electrical components and water. If you're uncertain or if the troubleshooting steps don't resolve the issue, it's best to seek professional assistance to avoid potential hazards.
12/17/2023 11:37:18 AM • Jacuzzi Home • Answered on Dec 17, 2023
3answers
Jacuzzi primo tub - need to take jet out
they twist out
5/15/2023 7:45:24 PM • Jacuzzi Home • Answered on May 15, 2023
2answers
My Jacuzzi bathtub won't start-188 error code
Hi, Please attempt to start the jacuzzi without any water and see if it functions. Then you can fill the jacuzzi up to 1/4th with water and check if it continues to run. If so, continue to one half full. If this jacuzzi breaks down at these water levels, then you'd need to call the manufacturer to advise on what part needs to be changed to get everything working again. Thank you.
8/21/2022 9:40:54 AM • Jacuzzi Home • Answered on Aug 21, 2022
Moen cartridge retainer broke tabs Stuck in valve how to remove
No, replace the whole thing. That is bad design and inferior parts. Ask Moen to replace it under warranty. They might say No, but then again, they might know of a fix or if they had a bad batch of plastic parts.
5/29/2022 2:03:32 AM • Jacuzzi Home • Answered on May 29, 2022
Jacuzzi toilet continually stops and starts during refill
Hello, Several things can cause this problem- if you post a picture of the inside of the tank so we can have a good look at how the fill/stop mechanism operates that would be great. We could more than likely identify some type of problem and solution. Not all flush/fill mechanisms are not the same but thats surely where your problem is UNLESS its in your water lines. I would love to help you just please provide photos and as much information as you can. Good luck! Mr.Mike
5/20/2020 5:32:45 PM • Jacuzzi Home • Answered on May 20, 2020
My Jacuzzi tub is not working and I'm not sure whether I need a new button, whole control panel kit, or switch. Thoughts?
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
6/29/2019 5:07:37 PM • Jacuzzi Home • Answered on Jun 29, 2019
Remove nt84000
There may be a video but you should be able to tell by looking at it too big screw under tank holds valve on big screw under tank holds valve on toilet-dual-steelwire-drive-flush-valve-a2312-p2302-[1]-zgzkf31tgqefbd1nldh0nf0r-3-1.jpg see: https://reviewmotors.co/jacuzzi-dual-flush-toilet-repair-parts
6/14/2019 4:39:25 PM • Jacuzzi Home • Answered on Jun 14, 2019
2007 Jacuzzi J355 will not heat
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
5/23/2019 4:22:08 PM • Jacuzzi Home • Answered on May 23, 2019
Re-set button on jacuzzi motor?
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
2/10/2019 6:29:29 AM • Jacuzzi Home • Answered on Feb 10, 2019
I need a user guide for my aeware jacuzzi
search google
12/7/2018 8:50:52 AM • Jacuzzi Home • Answered on Dec 07, 2018
Jacuzzi Fuzion Whirlpool Logo
6 questions posted
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
when push start button nothing happens
  • Home
