20 Most Recent
Nailers Ridgid Finish Brad Nailer R213bna Nail Gun Questions & Answers
I have a rigid 18v finishing nailer. It is about 6
I assume you have a R250AF18. The operator's manual for this nailer is
here. There's an exploded diagram with a parts list
here.
Could be a couple problems. A soft click sounds an awful lot like electric motor failure, but given that it's 6 moths old, this is a warranty issue. Rigid has a 3 year limited warranty on this tool. You can check
here for a service center near you or give them a call at 866-539-1710 and they'll take care of you. Ridgid's customer support is generally very good.
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to
www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
