20 Most Recent Black & Decker Black and Decker FIRESTORM 18v 18 volt hammer drill NEW Questions & Answers
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
4/24/2016 8:26:36 AM • Black & Decker... • Answered on Apr 24, 2016
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
4/22/2014 4:32:41 AM • Black & Decker... • Answered on Apr 22, 2014
0answers
What do the numbers mean near the front? Does it go around with less speed on 3 than 32?
this is most likely torque settings to keep operator from running screws to deep or snapping them
1/11/2012 4:50:58 PM • Black & Decker... • Answered on Jan 11, 2012
I cannot get one screw
You can take a drill bit around the same diameter as the head of the screw and drill the head out. It will get to a certain point and then break off. once you then seperate the housing you can take needle nose pliers and twist the rest of the screw out.
8/12/2011 1:24:28 AM • Black & Decker... • Answered on Aug 12, 2011
Old b&d 7277 lost total power after drilling 2
Get a new battery.
12/13/2010 10:53:27 AM • Black & Decker... • Answered on Dec 13, 2010
Looking for a black and decker firestorm 18v
go to dewaltservicenet.co and they have a locator section that you might find one locally.
10/26/2010 1:45:57 AM • Black & Decker... • Answered on Oct 26, 2010
HI Can i still get a 1hour Ni-Cd battery charger
if you could, i would check black and decker .com you can find parts and service centers close to you.or maybe at a battery depot
9/30/2010 11:14:08 PM • Black & Decker... • Answered on Sep 30, 2010
Can my black & Decker 3/8 drill model No.7143 go in reverse
The motor does not go in reverse.
12/10/2023 8:11:01 AM • Black & Decker... • Answered on Dec 10, 2023
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
8/5/2023 1:54:00 PM • Black & Decker... • Answered on Aug 05, 2023
Black & decker 40 volt battery is put on charger it flashes the green light twice then the red light flashes continueously qwhat could be the problem
hi, have you seen this ? https://support.blackanddecker.com/hc/en-us/articles/360012702998-If-my-battery-is-not-charging-what-can-I-try-#:~:text=If%20your%20battery%20is%20not,charger%20to%20try%20charging%20again. Now i don't think that's the issue , it more likely the cells won't take a charger or the bms electronic board has failed , with those battery packs it can be a electronics problem or a failed cell , One thing you might want to check is the actual connection to the battery pack..i seen a issue here where there is a bad connection , the charger won't charge regards Rob
3/13/2023 3:13:19 PM • Black & Decker... • Answered on Mar 13, 2023
2answers
Black + Decker Roto-Bit Storage Screwdriver 4V BDCS50. OK to leave on charger?
With that being said, be advised that leaving the screwdriver on the charger after fully charged may overcharge it and also shorten its battery life. Therefore, it is recommended to unplug the unit from the charger after charging.
2/25/2023 7:51:31 PM • Black & Decker... • Answered on Feb 25, 2023
Need switch for B&D drill. Cat # 1065-09 ETRM 254A
fixya doesent sell products repair shop or online order
1/10/2022 1:04:04 AM • Black & Decker... • Answered on Jan 10, 2022
Does a Black & Decker 3/8 variable speed drill number 7120 go clockwise
Has to so it can drill the hole .
9/16/2021 2:59:22 PM • Black & Decker... • Answered on Sep 16, 2021
Black & Decker Black and Decker FIRESTORM 18v 18 volt hammer drill NEW Logo
13 questions posted
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Drills
Most Popular Question
keyless chuck overtightened
  • Drills
