20 Most Recent Howard Miller Majestic Grandfather Clock 610-940 Questions & Answers
The easiest way to set the moon dial is to find out when the last full moon was, then turn the moon dial by hand to where the moon is straight up under the 15, then move it clockwise on click per day since full moon. If the last full moon was last Fri., and today is the following Tues. then you would move it a click for sat., one for sun, one for mon. and one for Tues. If you try to turn the dial, and it resists, wait till a couple hours later. Hope this helps
Howard Miller... | Answered on Mar 04, 2015
Clock oil, and a very small drop on each bushing, and pivot not on the gears in between the plates. Do not get oil on the hair spring if it has a balance wheel escapement. After oiling it's good to wiggle each gear back and forth to work the oil in. Good Luck in your adventure.
Howard Miller... | Answered on Jul 15, 2016
maybe you could get the fire dept to come by and test for high co levels. sounds to me like you need to
Home | Answered 4 hours ago
remember your posts are not threaded here so keep them all as one for the same issue
Home | Answered 5 hours ago
I am no expert on such matters but I hear it isn't easy even with modern radar and satellite observation though of course much depends on the size of the vessel, the construction and the range you wish to track it as well as whether you are fixed or mobile and your elevation.
The best way is to place a radio beacon aboard and have at least three listening stations equipped with direction-finding receiving equipment.
Home | Answered Yesterday
with a voltage tester aka multimeter set to dc volts
Home | Answered on Nov 22, 2020
replace the battery
I would suggest you ONLY DO THIS when the stove is COLD! Always Use Safety Gloves when touching a Stove.
Some stoves have a "Lift and Swing" latch where you use a handle to slide the door up a short amount then swing it outwards.
Others have a "Slide" latch where you slide a peg or handle across a slot to unlock the doors.
Another version of this can be a 'twist' instead of a slide.
Home | Answered on Nov 12, 2020
Find the Trouble and stop it. Find the Fire and put it out.
contact the maker of your mystery device
Home | Answered on Nov 03, 2020
Try to remove batteries and set clock again. Last night was time change and maybe that is the reason.
Home | Answered on Nov 01, 2020
Use any bleach based product that is sold to clean baths and showers. However you will need to give it time for it to work and this is how you do it. Put on a pair of rubber gloves and a pair of safety specs to protect your hands and eyes from bleach splashes. Now take a sheet of kitchen paper towel and roll it up or tear it into strips. Sellotape it in position at each end along the run of mould. Use more than one sheet if necessary. Then carefully wet the rolled up towel with bleach and when soggy push it firmly onto the mould. Leave overnight to do its work and take it off in the morning and you should find that the mould has gone. The paper towell should be disposed of carefully as it may be a health hazard (mould and bleach) so put it in a rubbish bag as soon as possible.
Home | Answered on Oct 30, 2020
Request instructions directly from Miomare.
Home | Answered on Oct 29, 2020
Howard Miller Majestic Grandfather Clock 610-940 Logo
1 questions posted
Top Howard Miller Home Experts
john h
Tom Chichester
Are you a Howard Miller Home Expert? Answer questions, earn points and help others
View Most Popular
Howard Miller Home
  • Howard Miller Home
Most Popular Question
get moon cycle top work
  • Home
