20 Most Recent Staples Upholstery Air Stapler Uses Senco 14 Crown Questions & Answers
How do you reload staples into a Boston Standup style stapler?
Questions like this need a model number. See if this helps
How to Load Staples in a Boston 135 Stapler
Weekand https://www.weekand.com > ... > Furnishings Jul 21, 2017 - Insert heavy-duty staples into the staple holder, pushing back on the spring that feeds the staples forward until the staples are loaded. Gently ... ..
3/14/2024 5:46:19 AM • Staples Tools &... • Answered on Mar 14, 2024
How to load staples into a P3 stapler
Pull rear lever to open magazine and load staples. The Bostitch P3 uses SP19 1/4? staples.
Bostitch P3 Stapler - Agricultural Supplies - MIDCO Global
11/17/2023 8:18:17 PM • Staples Tools &... • Answered on Nov 17, 2023
Staples don't close on heavy duty stapler?
Usually the plate will swivel 180 degrees to give an open staple for easy removal, or a closed staple for permanent fastening. Push up from underneath and turn it. https://www.google.com/search?q=Swingline+heavy+duty+stapler+manual ..
9/19/2023 4:34:25 AM • Staples Tools &... • Answered on Sep 19, 2023
2answers
Swingline 270 goes through the motions, but no staples are coming out. It worked fine till it ran out of staples. I replaced them, but no staples are forthcoming
The new staples aren't in correctly of the last staple in the old magazine, is jammed that the end. You should try to never run completely out. WOW, a thousand bucks for an office stapler!! https://www.google.com/search?q=Swingline+270 ..
6/6/2023 7:53:12 PM • Staples Tools &... • Answered on Jun 06, 2023
How do I load my Rapid Classic 9 heavy duty stapler? I can open the back, and slide out the spring, but when I put the staples on it doesn't seem to work. Thanks in advance!
Rapid classic 9: kan enkel vanuit de achterkant gevuld worden. grote nieten zitten strak en glijden daarom er niet makkelijk uit. Haal de veer eruit. (Achterkant) Schuif de klem op de voorkant naar voren. (Zet er een schroevendraaier tussen). Druk het mechanisme een beetje in om het frontplaatje te verwijderen. De hamer (plaatje achter de frontplaat dient de tekst:FR aan de voorkant te houden) Druk met een lange schroevendraaier de nieten die erin zitten naar achteren, en haal deze eruit. Zet de hamer en frontplaat weer op de plek, en schuif de klem terug. vul het apparaat met de nieten die u wilt gebruiken.
12/6/2022 10:17:46 PM • Staples Tools &... • Answered on Dec 06, 2022
Worx WX840 does not hammer in nails but it does staples
https://toolsmirror.com/nail-gun-not-shooting-nails/ This article may help you find the problem.
10/7/2022 2:20:09 PM • Staples Tools &... • Answered on Oct 07, 2022
I have a Ns150 crown stapler and the drive pin is not going all the way up so the staples can move to be shot
try oil into ram shaft if still problem will need to tear apart to see if debris or damage
3/1/2022 12:31:03 AM • Staples Tools &... • Answered on Mar 01, 2022
Staples for swingline model 34201
T-50 is the size staple for that one.
12/2/2021 7:16:40 AM • Staples Tools &... • Answered on Dec 02, 2021
I have a LT-207 stapler. I need to find some 7mm staples ? Does your company have such an item? Appreciate any help! Richard
Sorry, This is not a sales website. This is a forum for repair advice. If it uses a standard size staples most good stationary suppliers will have them in stock.
11/17/2021 8:10:58 PM • Staples Tools &... • Answered on Nov 17, 2021
Where can i get a replacement spring assy. for loading staples on a powershot pro mod. no. 8000 ?
manufacturer -tool repair shop --online search
9/14/2021 10:36:17 PM • Staples Tools &... • Answered on Sep 14, 2021
I have a Duo-Fast electric stapler model # T.E. 3320. Are there 3/8 staples for it available now?
If your still looking for staples for a duo-fast 3320 my stapler shorted out . I have two boxes each of 3/8 & 1/2 inch staples if your interested can reach me at drichc56@hotmail.com
9/11/2021 9:54:20 PM • Staples Tools &... • Answered on Sep 11, 2021
What if the 5/8 by 1/4 inch narrow crown staples will not go into the slot?
Then they are the incorrect staples for that unit.
5/11/2021 6:06:52 PM • Staples Tools &... • Answered on May 11, 2021
A small metal piece fell out of my 50509 staples stapler while reloading. Where does it go
on the end of the rod after the spring is on
4/23/2021 12:58:55 AM • Staples Tools &... • Answered on Apr 23, 2021
I have a rexel 2001 staple gun. It says on it to use Rexel 2001/6 or 2001/8 staples in it but I can't find that particular size anywhere! Can anyone tell me the equivalent size to look for please?
try where you got it .OR https://www.google.com/search?q=rexel+2001+staple+gun&oq=rexel+2001+staple+gun&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/6/2021 8:31:17 AM • Staples Tools &... • Answered on Apr 06, 2021
Staples Upholstery Air Stapler Uses Senco 14 Crown Logo
Popular Tags
0 questions posted
Top Staples Tools & Hardware - Others Experts
vince
Jesse Walters
Jesse Walters
Paul Bade
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Staples Tools & Hardware - Others
Most Popular Question
mastercraft heavy duty stapler 57 7945 6
  • Tools & Hardware - Others
