20 Most Recent Heavy Duty Arrow T50 Staple Gun Questions & Answers
0answers
Pull out the spring loaded mechanism out
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution. Thank you for using FixYa.
2/13/2012 7:58:57 PM • Heavy Duty Arrow... • Answered on Feb 13, 2012
I don't understand how to
we have one, you push in at the back and pull down take out the rod put the staples in and put rod back in and push up it locks itself, hope it helps
2/1/2011 1:55:21 AM • Heavy Duty Arrow... • Answered on Feb 01, 2011
How do I open a model T-50 staple gun?
On the rear of the stapler (if you look at the picture on this web page, the lower right) there is a metal piece that you push in, then down slightly, to unlock. When you release it, a spring loaded bar and follower will come out. You will see where the staples slide in. Put the follower back in the grooves and reinstall.
8/10/2010 11:59:19 PM • Heavy Duty Arrow... • Answered on Aug 10, 2010
Instruction manual - Surebonder 5650 All In 1 Heavy Duty Staple Gun
Contact Surebonder for assistance using their form on their website. https://surebonder.com/pages/contact-us
3/22/2020 10:20:12 AM • Heavy Duty Tools... • Answered on Mar 22, 2020
EZ Squeeze 130 heavy duty stapler - feed bar
https://www.amazon.com/Bostitch-Squeeze-Stapler-Reduced-B8130/dp/B004I2MG1W
3/21/2020 9:26:28 AM • Heavy Duty Tools... • Answered on Mar 21, 2020
How do I adjust the depth the brads are counter sunk
There is a dial located by the business end of the Brad that adjusts the depth it fires. Also make sure you air pressure ( written on the stapler ) is set to level issued by the manufacturer. It'll say something like max pressure 90 psi. That would mean you will need to adjust the regulator pressure on your compressor to no more then 90 psi or to what ever number that is written on that sticker. Use a test piece of wood and turn the pressure down if you have no luck until you get the desired results.
4/24/2018 2:34:58 PM • Heavy Duty Tools... • Answered on Apr 24, 2018
Heavy Duty Arrow T50  Staple Gun Logo
17 questions posted
Top Heavy Duty Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Heavy Duty Tools & Hardware - Others
Most Popular Question
pull out spring loaded mechanism out
  • Tools & Hardware - Others
