Actually any good electronics parts store will have parts to make connectors. I even made a wiring harness one time for a friend's amplifier system. Connectors are not a proble unless they were the decorative type, those are hard to find.
I think this is an old Blaupunkt where the code cannot be calculated using the serial Number.
It will require specialist advice
Try asking here for free advice....CLICK HERE
Mention FixYa
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
Hi I have suzuki ignis too and I have problem with radio code too...but I am from slovakia and my english is so amynous...and I dont understant this web side (www.ukbookshelf.co.uk) its free ?
39101-86G1
ID: 39101-86G1.......like gedwards80 on the top :)
Check your cable connections for the TV and the receiver or for the video devices.The signal that is being received from your TV might be weak or poor.You will need to contact your service provider to improve the signaling strength for the TV..
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
