20 Most Recent Tally T8024 Laser Printer Questions & Answers
Click the link below and it will show you where you can download the driver for Tally 8024.
http://drivers.brothersoft.com/tally-t8024-printer-pcl-driver-ver-01.02-22736.html
Hope this helps. Rate if it works. Thanks
Tally T8024... | Answered on May 03, 2011
Try this: http://www.bravofiles.com/download/Tally-T8024-PCL6-cjG3EhpGa5.html
Tally T8024... | Answered on Mar 05, 2011
The 'Set Drum" error indicated the printer is not detecting the drum cartridge as being located in the printer.
I would recommend doing the follwoing;
  1. Ensure the drum cartridge locates correctly in the printer. Remove it and re-seat if necessary.
  2. Ensure the top cover (the one that opens upwards to change the drum) shuts correctly, this cover pushes the drum into the printer.
If the above actions do not fix the problem, I am afraid the covers will need to come of the printer. There is a gear mechanism located on the left side of the printer that operates when the top cover closes.
This gear mechanism will need to be aligned with the alignment marks, it sounds like the gears will have slipped and the timing is slightly out.
Tally T8024... | Answered on Feb 18, 2011
Hi
Check the following possibilities that may causing the error message.
1. Some times more paper may be taken in the paper feed area, check for any other paper jam in other area of the printer.
2. Remove all the printer drives, ports and uninstall the printer software and once again reinstall it by following steps given below
Start - Control Panel - Add and Remove Programs - Remove the program in the list called Tally Laser printer.
By now you have uninstall the software and now reinstall the software with the available cd given at the time of printer purchase and start printing.
Thank you
Tally T8024... | Answered on May 11, 2010
its possible with internet connection ...u can uninstall
Tally T8024... | Answered on Feb 26, 2010
pLEASE UNINSTALL THE PRINTER DRIVER AND REINSTALL IT AGAIN..........THAT SHOULD HELP..
Tally T8024... | Answered on Jan 31, 2010
Tally T8024 Paper Tray
Part Number 050K50140
Description TRAY ASSY LOW TAL
Call Toll Free
1.800.544.5345
(Please give be a big thumbs up when you rate my answer, thanks.)
Tally T8024... | Answered on Jan 28, 2010
You may want to order a Maintenance Kit, which replaces the rollers, transfer roller and fuser, which will basically set your printer back to 0 pages and stop frequent jams also. No need to spend all that money on a new one.
Tally T8024... | Answered on Nov 05, 2009
You can access the the NETWORK men on the T8006 by powering the pritner ON holding down TRAY
You should then be able to change your IP Get method and network settings.
Exit the menu by pressing the UP Arrow untill you see RESET on the display, then wait wilst the pritner restarts and it should have saved the new network settings.
Tally T8024... | Answered on Oct 02, 2009
it may be due to incomplete installation as well as may be some files are deleted or removed
Tally Office... | Answered on Feb 10, 2020
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
Tally Office... | Answered on Aug 04, 2018
Tally T8024 Laser Printer Logo
Popular Tags
16 questions posted
Top Tally Office Equipment & Supplies Experts
Zaid Anarwala
Zaid Anarwala
CheckitRight
CheckitRight
Lee Hodgson
Lee Hodgson
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
when think about replacing t8024
  • Office Equipment & Supplies
