20 Most Recent
Tally T8006 Laser Printer Questions & Answers
I want the drivers
Go to their website and download the drivers from there using your make and model number
Printer error TALLY T8006 SVC F4 ERROR
I belive the SVC F4 error indicates the fuser fan is not functioning.
Check the fan is connected correctly, also check if the fan is working.
If the fan is not working it may need ot be replaced, alternativly it may be a IOD1 Board or the MCTL board
Tally t8006 colour laser constantly gives paper
Please unplug the printer cable eject the paper and uninstall the printer driver comletly and restart the computer after that reinstall the printer driver and insert the paper in paper tray.
it should be work now
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
- Power the printer on while holding down MENU/ENTER key
- Release the key when the display shows "Utility Menu Clear FC Roll"
- If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
- When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
- Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
- Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Rosener
T8006
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser.
The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet.
I would try a different toner cartridge first to see if that solves it.
