20 Most Recent Hitachi Wh18dl 18v Liion Cordless Impact Driver Questions & Answers
Hi Mark,
R8 Should be a 1000 Ohm 1/4Watt resistor
Rgds Ray
Hitachi Wh18dl... | Answered on Jun 18, 2016
Sounds like the armature in the motor has a problem. Check the brushes too.
Hitachi Wh18dl... | Answered on Jan 17, 2014
I know nothing about these tools but Hitachi produce quality gear that isn't usually prone to intermittent faults. If I was faced with your situation I would check the power cord for internal breaks and check the internal connections and then investigate the functioning of any safety device that might be incorporated into the design - such a powerful tool would surely have safety built in or modern legislation would never allow them to be used on site.
It was just a sort of gut feeling as it seems to be the built in safety that fails on many tools...
Hitachi Tools &... | Answered on Sep 28, 2020
I've had that happen before and what I found was one of the Staples or nails had misfired and wedged before leaving the gun. read the manual on how to get to it for that particular model and also it might be a good idea to adjust your pressure accordingly to keep it from happening again. If the force isn't set proper then a nail could Jam , block the mouth and not allow any other nails to exit. It's very easy to do and not that hard to fix once you've done it at least once. Good luck.
Hitachi Tools &... | Answered on Feb 11, 2019
The number one issue is bad fuel - even if you just purchased it, turn the cell over and check the date stamped on the bottom (often stores don't rotate their stock)
If the fan starts when the nose is depressed but there is no spark then I would investigate the spark wire (make sure there are no nicks or cuts that may short to ground) and the ESU (Electronic Spark Unit).
Hitachi Tools &... | Answered on Feb 02, 2019
Have you kept it properly oiled? It might be jammed because it's too dry.
Hitachi Tools &... | Answered on Oct 24, 2018
Sounds like it's overly dry; needs oiling. Or there is something clogging the air lines or the air chamber inside the gun.
It sounds like you're producing difficulties yourself by attempting to solve this problem rather than seeking at why their can be a difficulty inside very first place https://www.fliptite.com/
Hitachi Tools &... | Answered on Oct 05, 2018
Check the date code on the bottom of your fuel - it doesn't matter if it feels full or that you just bought it, many stores don't rotate their stock. The #1 issue with these is bad fuel.
Hitachi Tools &... | Answered on May 30, 2018
just wondering if you are putting enough down pressure
on it before you pull the trigger.?
Hitachi Tools &... | Answered on Jan 07, 2018
1. Have you adjusted the air pressure to at least 100 PSI?
2. Have you cleaned and lubricated the gun per manufacturer's instructions?
3. Are you driving nails into hard wood (oak, walnut, etc.)? Some guns are simply not powerful enough to handle extremely hard woods.
Hitachi Tools &... | Answered on Dec 08, 2017
1) Oil it per the operating instructions.
2) Use only high-quality fasteners. I recommend Hitachi or Bostitch, although those from Harbor Freight Tools are largely trouble-free.
3) Make sure nails are properly inserted in the gun.
4) Check to confirm that your gun is receiving adequate air pressure. With that nailer, I'd suggest 95-105 psi.
Hitachi Tools &... | Answered on Dec 02, 2017
Hitachi Wh18dl 18v Liion Cordless Impact Driver Logo
7 questions posted
Top Hitachi Tools & Hardware - Others Experts
Joe Garcia
Joe Garcia
JOHN LAPIER
Parson's Repair...
Parson's Repair...
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Tools & Hardware - Others
Most Popular Question
resister r8 hitachi uc18yrl charger
  • Tools & Hardware - Others
