YES. You have dirt and grime inside.Go to a Lowes or Home depot and look in the nail gun dept. Get a can of Paslode tool cleaner.( white aerosol can with orange and black label) $8 a can. While running tour drill,(over a sink or outside) spray it all inside aroud trigger and motor,turn in all directions and watch how much gunk will wash out. You'll be suprised at what a difference this will make and it will prolong the life of your tool. Works great on all battery powered tools and air tools ! I highly recommend it, but don't buy them out of it , leave some for me. I;m allmost out of it.
The screw is a reverse thread torx t20 head. One you have the torx t20 screw driver from a hardware or tool store you need to turn it to the right to loosen the screw.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Possible reasons for this behavior:
Blinks Long (Red Light): If your battery is too hot, the charger will blink the red light rapidly and for an extended duration. To prevent this, ensure that your battery is not exposed to direct sunlight or excessive heat. Give it some rest to cool down.
Blinks Short: If the battery is too cold, it will blink short and fast. This could be due to prolonged exposure to cold temperatures or the battery being idle for an extended period. Allow the battery to charge for a while or bring it to room temperature to resolve this issue.
Blinks Very Fast (Doesn't Go Away): If the light is blinking very fast and persists, it indicates that your battery has gone bad and needs replacement.
A photo would greatly help with your issue, are both wires still attached to the capacitor?? in not, the capacitor must be replaced with one of the same value,
if the capacitor is ok, look for a wire with solder on the end but nothing else attached to it, or a solder point on a card with a hole in it or a solder joint that has broken free from the card,,, if you can solder well, and have the equipment,. it is good at this point because You'll need to re-solder them back together,,
again a photo will help me greatly in telling you exactly how to fix
https://www.youtube.com/watch?v=pNDgV_6k12E
Reverse and Forward Mode: Try putting the drill in reverse mode and hit the trigger, then forward mode. If that doesn't work, tap the tip on the driveway but don't slam it. It should release .
Use a Wrench: First, make sure that the chuck is in the locked position. Next, use an allen wrench to loosen the set screw on the side of the chuck. Finally, unscrew the drill bit from the chuck .
Remove Chuck Collar: Use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck .
It's going to be a zener diode, that's the easy part, you will need to know the voltage as well, only way to know that is find a good charger and measure the voltage drop across the diode with a multimeter or find a schematic.
Here are the wire placements for the switch of a DeWalt DWD520 hammer drill:
The red wire from the motor goes to the top left terminal on the switch.
The black wire from the motor goes to the top right terminal on the switch.
The white wire from the power cord goes to the bottom left terminal on the switch.
The black wire from the power cord goes to the bottom right terminal on the switch.
It's always recommended to double-check the manual or contact DeWalt customer service for confirmation, as wire placement may vary depending on the specific model and year of manufacture.
The red light flashing at the rear of your DeWalt D26501 could indicate a few different issues with the tool. Here are some potential causes and troubleshooting steps you can try:
Battery issue: If you're getting full power but the tool won't run, it's possible that the battery is not delivering the correct voltage or is not making proper contact with the tool. Try removing the battery and reseating it firmly in the tool, making sure it clicks into place. If the battery is still not delivering power properly, try charging it fully or using a different battery to see if that resolves the issue.
Trigger issue: If the red light flashes but the tool does not run when you press the trigger, it's possible that there is an issue with the trigger itself or with the wiring connecting it to the motor. Try checking the trigger for any visible damage or debris, and make sure it moves freely when pressed. You may also need to check the wiring connections inside the tool to ensure they are secure and not damaged.
Motor issue: If neither the battery nor the trigger seem to be the issue, it's possible that there is a problem with the motor itself. This could be caused by a number of factors, including a burned-out motor or a malfunctioning component inside the tool. If this is the case, you may need to take the tool to a professional technician or contact DeWalt customer service for assistance.
Overall, troubleshooting issues with power tools can be challenging, and it's important to take appropriate safety precautions when working with them. If you're unsure about how to proceed or are not comfortable working on the tool yourself, it's best to seek professional assistance.
A small part that helps the switching is probably broken.
Go to the dewalt site and the service online in order to find the faulty part. It would be cheap if you want to buy it. Your can repair it by yourself.
There is a torx headed screw inside the chuck that is reverse thread (Right hand to loosen) - remove that then the chuck will spin off standard thread (Left hand loosen)
Most of the time I chuck a 1/2" allen wrench into the chuck, mount the drill in a vise, and strike the wrench with a hammer to get the chuck off
