20 Most Recent
Stihl Concrete Cutoff Saw Carburetor Ts 700 800 Hs Questions & Answers
Stihl ts 350 super cut saw died in the middle of cutting a brick
Can you get a compression tester to check the compression? With the throttle wide open, the choke OFF, and the decompression valve (if so equipped) NOT engage, pull the engine over 3-5 times or until the gauge quits rising. You would like to see 90psi or more and if it is at 60 or less then it is most likely a scored piston and cylinder or bad rings. If the compression is good you need to check for spark. If it has good spark then it will most likely be fuel related. Often a complete tear down and rebuild of the carb is what is required.
10/14/2022 4:35:02 AM •
Stihl Saws
Answered
on Oct 14, 2022
Idle speed screw reset on a stihl br 350
Turn the screw gently clockwise until it won't go in any more. Then turn it anti (counter) clockwise 1 complete turn. That should enable it to start but you will probably need to adjust it when the engine is warm. Failure to start can be because of a range of causes so I suggest you check the basics first like ensuring the fuel is fresh, that there is spark at the plug and that the choke is turned on if the engine is cold.
4/6/2019 12:01:50 PM •
Stihl Saws
Answered
on Apr 06, 2019
