20 Most Recent Stihl Cutoff Saw Starter Recoil Cover Ts 350 360 Questions & Answers
Go to Stihlor ts350 or 360 . com This will get you a diagram. good luck
Stihl Cutoff Saw... | Answered on Feb 25, 2011
handles have to be removed first
Stihl Saws | Answered on Nov 20, 2019
Hi Harold-
Here is a youtube video STIHL TS 350 Super Cut Off Saw (Pulling The Engine Apart) https://www.youtube.com/watch?v=DIlfGvFvIb4
Hope this helps.
Stihl Saws | Answered on Oct 27, 2019
obviously it's not getting gas. remove the carb and recheck it. some have a plastic piece over the intake and output to keep the interior clean during transit. Forgetting to remove it will cause it not to get gas. Either that or the float is stuck closed, something like that. If the carb is new out of the box, they sometimes have a piece of plastic or something inside the float bowl to keep the float from banging around during shipping ect. Check that too.
Stihl Saws | Answered on Oct 09, 2019
Check the fuel line in the tank to see if it's plugged. Also there could be crack or air leak in the full line not allowing gas to get sucked in. Just some thoughts if you haven't looked at this yet.
Stihl Saws | Answered on Jun 26, 2019
wear and tear or improper usage
Stihl Saws | Answered on Jun 03, 2019
Primer bulb to in tank filter - return line from carb to top of fuel tank.
Stihl Saws | Answered on May 19, 2019
WITH A FLYWHEEL PULLER
Stihl Saws | Answered on May 11, 2019
Check shutoff switch, wires for grounding, magnet strength on flywheel. If OK replace ignition module .
Stihl Saws | Answered on May 08, 2019
Turn the screw gently clockwise until it won't go in any more. Then turn it anti (counter) clockwise 1 complete turn. That should enable it to start but you will probably need to adjust it when the engine is warm. Failure to start can be because of a range of causes so I suggest you check the basics first like ensuring the fuel is fresh, that there is spark at the plug and that the choke is turned on if the engine is cold.
Stihl Saws | Answered on Apr 06, 2019
check the air filter and also exhaust for carbon buildup...two stroke right??
Stihl Saws | Answered on Apr 04, 2019
Most Stihl machines use 0.5mm spark gap
Stihl Saws | Answered on Mar 13, 2019
call a stihl dealer
Stihl Saws | Answered on Jan 17, 2019
check the on off switch for continuity
Stihl Saws | Answered on Dec 25, 2018
Stihl Cutoff Saw Starter Recoil Cover Ts 350 360 Logo
Popular Tags
5 questions posted
Top Stihl Saws Experts
rlev_7
Level 1 Expert
Frank
Are you a Stihl Saw Expert? Answer questions, earn points and help others
View Most Popular
Stihl Saws
  • Stihl Saws
Most Popular Question
concrete cutoff saw made stilht
  • Saws
