20 Most Recent Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835 Questions & Answers
Take loose the nut that holds on the flywheel. Then hold the flywheel with a pair of pliers and lift it off of the workbench, make sure the flywheel nut is even with the top of the crankshaft. As not to damage the crankshaft of the threads. Then lightly strike the nut/crankshaft until the flywheel comes loose. It should only take a couple of taps.
Stihl Chainsaw... | Answered on Mar 04, 2020
You need to get a 2 or 3 jaw puller to remove it. The 3 is more easy to use if there is a place for all 3 jaws to grab. If you can only can get 2 jaws placed the placement is a little more tricky.
Stihl Chainsaw... | Answered on May 03, 2016
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Hi and welcome to FixYa. I am Kelly
You are going to have to rebuild your carb and get a
GASKET & DIAPHRAGM KIT
  • TILLOTSON DG-2HL/DG-5HL
  • Fits all HL model carburetors
One of your many diaphragms or gaskets is leaking even though it is clean all it takes is a pin hole to cause havoc!
This link provided as a picture reference only:
http://www.gardenhirespares.co.uk/product/173
http://www.gardenhirespares.co.uk/images/1100_orig_listing.jpg
US source for the same kit:
http://ssl.jackssmallengines.com/jacks-checkout/shopping-cart.aspx?CFID=179837&CFTOKEN=92541317
Make sure to download this 8 page manual to help you with the carb repairs:
http://www.tillotson.ie/docs/techinfo_HL_US.pdf
Just make sure you have good fuel flow to the carb fuel inlet from the gas tank with a good rate of flow.
When you finish it will work great if you did it properly. You will for sure have to adjust the fuel mixture screws after the re-build.
Thanks for choosing FixYa,
Kelly
Stihl Chainsaw... | Answered on Oct 11, 2013
clean flywheel and check coil try new plug
Stihl Chainsaw... | Answered on Sep 22, 2012
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Stihl Chainsaw... | Answered on Sep 21, 2012
Clean it again you missed something or maybe a gasket is on wrong. If you went through all of that it should run fine. Stihl usually rebuilds and runs well. Slow down turbo maybe you got a little ahead of yourself. Good Luck...
Stihl Chainsaw... | Answered on Aug 29, 2012
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Stihl Chainsaw... | Answered on Jul 20, 2011
This was a problem with the original unit. They have since fixed this problem. There is a kit you can get from your Stihl dealer. It is a fuel tank/ air filter kit. You would have to replace the tank housing which is where the air filter bolts up to. You can have the dealer do it, or you can do it yourself. The kit is not cheap, but it will cure your problem. I've used a hacksaw to cut through the old bolts. Then you can change out the tank housing.
Stihl Chainsaw... | Answered on May 10, 2011
If the unit is leaking fuel out of the carburetor when the unit is not in use then it is usually the needle sticking open. This can be from a piece of grass or other debris getting under the needle and keeping it open. Alternatively it could be a bad diaphragm that is leaning on the needle and keeping it open.
As always it is recommended that you take the unit to a Stihl dealer with a Gold Certified Technician for parts and repairs.
Stihl Chainsaw... | Answered on Mar 30, 2011
The problem could be with the kill wire grounding out on the housing or the ignition coil could have gone out. Take out the spark plug and dis connect the kill wires off of the coil. NOTE: If you do not take out the spark plug to test for a spark then you run the risk of the unit starting up and not being able to shut it off. With the spark plug out of the engine and the kill wires dis connected. Put the spark plug boot on the spark plug and rest the spark plug on the engine (anywhere there is bare metal from the cylinder is O.K.) pull on the recoil starter and see if there is any spark present. If there is still NO spark present then you need to replace the coil. If there IS spark then you need to replace the kill wires with a new set.
Hi amills back the idle mixture out 1quarter turn. GOOD LUCK
Stihl Chainsaw... | Answered on Feb 25, 2011
handles have to be removed first
Stihl Saws | Answered on Nov 20, 2019
Hi Harold-
Here is a youtube video STIHL TS 350 Super Cut Off Saw (Pulling The Engine Apart) https://www.youtube.com/watch?v=DIlfGvFvIb4
Hope this helps.
Stihl Saws | Answered on Oct 27, 2019
obviously it's not getting gas. remove the carb and recheck it. some have a plastic piece over the intake and output to keep the interior clean during transit. Forgetting to remove it will cause it not to get gas. Either that or the float is stuck closed, something like that. If the carb is new out of the box, they sometimes have a piece of plastic or something inside the float bowl to keep the float from banging around during shipping ect. Check that too.
Stihl Saws | Answered on Oct 09, 2019
Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835 Logo
16 questions posted
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
View Most Popular
Stihl Saws
  • Stihl Saws
Most Popular Question
stihl ts350 cut off saw put fuel
  • Saws
