20 Most Recent
Stihl Concrete Cutoff Saw Rewind Recoil Spring Ts 400 Questions & Answers
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Stihl Concrete...
Answered
on Apr 27, 2013
Trying to put recoil back together, how does
There is a groove where the entire plastic case around the spring will go. It will only fit one way.
Be careful when installing the spring, if it gets lopsided. IE. Part of the spring sits on the groove for the spring housing and the rest of the spring housing fits into the the groove, the spring will come out of the spring housing.
Stihl Concrete...
Answered
on Mar 30, 2011
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
Stihl Concrete...
Answered
on Feb 25, 2011
Idle speed screw reset on a stihl br 350
Turn the screw gently clockwise until it won't go in any more. Then turn it anti (counter) clockwise 1 complete turn. That should enable it to start but you will probably need to adjust it when the engine is warm. Failure to start can be because of a range of causes so I suggest you check the basics first like ensuring the fuel is fresh, that there is spark at the plug and that the choke is turned on if the engine is cold.
Stihl Saws
Answered
on Apr 06, 2019
