20 Most Recent Honda 13 Hp 4000psi 4gpm Pressure Washer Ez4040 Pump Questions & Answers
The pressure relief valve could be stuck open or faulty. The check valves may be stuck or plugged up. Try thoroughly clean these parts and see if that helps.
Bob
Honda 13 Hp ... | Answered on Apr 02, 2015
does the engine die or the pressure if its the engine leave the gas cap loose and see if it stays running the vent could be plugged is it loosing spark when it dies check it for spark is it fuel does it fire back up or does it need to cool off for a while like the coil is bad
Honda 13 Hp ... | Answered on Apr 27, 2012
sounds like a carb problem
Honda 13 Hp ... | Answered on Sep 09, 2010
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Honda 13 Hp ... | Answered on Jul 12, 2010
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Honda Plumbing | Answered on Feb 18, 2014
The pressure produced by a pump depends on it's capacity and efficiency, the power of the motor driving the pump and the resistance of the pipework.
Without the resistance provided by the usual pipework the pump produces negligible pressure and just merely moves the liquid.
Given the motor power and pump capacity/efficiency are fixed values, the only reason the pressure would increase is the resistance provided by the pipework has increased.
Plumbing | Answered on Jul 30, 2020
Visit Lowes or Northern Tools stores to ask for assistance.
Plumbing | Answered on Jul 02, 2020
If it isn't too late, I have a single crystal knob also. Couldn't find another when one of mine broke, so I bought two in the chrome finish. Let me know if you're interested in my (unbroken!) crystal knob.
Plumbing | Answered on Jun 30, 2020
  1. Step 1: TURN OFF WATER.
  2. Step 2: PRY OFF HANDLE.
  3. Step 3: REMOVE HANDLE FROM ASSEMBLY.
  4. Step 4: REMOVE THE RETAINING NUT.
  5. Step 5: REMOVE THE RETAINING CLIP.
  6. Step 6: REMOVE THE O-RING.
  7. Step 7: REPLACE THE CARTRIDGE.
  8. Step 8: REINSTALL THE O-RING.
Plumbing | Answered on Jun 17, 2020
I doubt the kitchen tap is actually turning itself on - or is it?
Perhaps fluctuations in water pressure are defeating the tap...
More details would have been helpful, such as mentioning the tap design (traditional or quarter turn type?) and when the hammering noise happens?
Hammering is often caused by a worn tap. When turned partly on the jumper can vibrate and cause the pressure in the pipe to fluctuate and magnify the noise, especially when there is a long run of pipe that is inadequately clipped to the wall...
Plumbing | Answered on Jun 06, 2020
OPEN A FAUCET IN THE KITCHEN AND WAIT IF WATER COMES THEN YOU HAVE NO PROBLEM MY GUESS IS THERE IS TOO MUCH AIR PRESSURE IN THE TANK . IF YOU HAVE AN ELECTRIC WATER HEATER YOU HAVE ALREADY BURNT THE ELEMENTS OUT IN IT
Plumbing | Answered on May 26, 2020
How to Remove the Sprayer on a Moen 7900 Faucet
  1. Turn off the valves under the sink by rotating the valve handles counterclockwise.
  2. Hold the hose in one hand and push upward on the hydrolock connection with the other to disconnect the sprayer from the diverter. ...
  3. Pull the sprayer straight upward and out of the guide.
https://homeguides.sfgate.com/remove-sprayer-moen-7900-faucet-83422.html
Plumbing | Answered on May 19, 2020
HOW MANY DIFFERENT ONES ARE IN THE BATHROOM?USE HEAD FOR SOMETHING BESIDES A HAT RACK
Plumbing | Answered on May 10, 2020
The LED indicator light on the base of the faucet will start blinking red when it is time to change the batteries. If the batteries are not replaced in time, the faucet will still function with manual operation. ... Place the battery pack as close to the floor of the cabinet as possible.
https://worldwide.deltafaucet.com/customersupport/faq/touch2o+technology/index.html
https://www.youtube.com/watch?v=CVtLpdxJbSU
https://www.youtube.com/watch?v=vf9xf3vMsGM
Plumbing | Answered on May 09, 2020
Possible remedies are: allowing the water to run for several days (in the case of a new well), screen installation or replacement (for a sand and gravel well), or installing a liner in a sandstone well.
https://www.networx.com/article/black-specks-in-your-water-ew-how-to-g
Six coman cause:
https://www.reicheltplumbing.com/plumbing-blog/6-common-causes-of-black-specks-in-your-water/
Submersible pumps usually use #10 non-detergent oil.
Plumbing | Answered on May 07, 2020
Honda 13 Hp  4000psi 4gpm Pressure Washer Ez4040 Pump Logo
6 questions posted
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
ray gallant
Renee Knafel-Bullock
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Honda Plumbing
  • Honda Plumbing
Most Popular Question
honda 4000 motor runs great pump not
  • Plumbing
