20 Most Recent Honda Horizontal OHV Engine for Non Pumps 160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2 Questions & Answers
valve clearance 10 thou on feeler blade
Honda Horizontal... | Answered on Feb 07, 2018
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Honda Horizontal... | Answered on Sep 14, 2014
Try posting in the automotive area! You should get somebody there that can help.
Honda Horizontal... | Answered on Jun 18, 2014
hi under the carb is a drain bowl .shut the fuel off then take the bowl off 10 mm bolt .then you will see a plastic float hold the float up and turn the fuel on if fuel is cuming out the needle might have dirt on it. turn fuel off now pull the pin out that holds float in place the needle will come down with float spray needle and where needle is seated with carb cleaner now re fit needle and float and hold float up and turn fuel on if no fuel comes out problem sorted. drain oil and fill with new oil.if still leaking fuel you need a new needle
Honda Horizontal... | Answered on Nov 28, 2013
sounds like the coil
Honda Horizontal... | Answered on Aug 31, 2012
sounds like low idle screw could be turned up a bit
Honda Horizontal... | Answered on Sep 09, 2010
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Honda Plumbing | Answered on Feb 18, 2014
The pressure produced by a pump depends on it's capacity and efficiency, the power of the motor driving the pump and the resistance of the pipework.
Without the resistance provided by the usual pipework the pump produces negligible pressure and just merely moves the liquid.
Given the motor power and pump capacity/efficiency are fixed values, the only reason the pressure would increase is the resistance provided by the pipework has increased.
Plumbing | Answered on Jul 30, 2020
Visit Lowes or Northern Tools stores to ask for assistance.
Plumbing | Answered on Jul 02, 2020
If it isn't too late, I have a single crystal knob also. Couldn't find another when one of mine broke, so I bought two in the chrome finish. Let me know if you're interested in my (unbroken!) crystal knob.
Plumbing | Answered on Jun 30, 2020
  1. Step 1: TURN OFF WATER.
  2. Step 2: PRY OFF HANDLE.
  3. Step 3: REMOVE HANDLE FROM ASSEMBLY.
  4. Step 4: REMOVE THE RETAINING NUT.
  5. Step 5: REMOVE THE RETAINING CLIP.
  6. Step 6: REMOVE THE O-RING.
  7. Step 7: REPLACE THE CARTRIDGE.
  8. Step 8: REINSTALL THE O-RING.
Plumbing | Answered on Jun 17, 2020
I doubt the kitchen tap is actually turning itself on - or is it?
Perhaps fluctuations in water pressure are defeating the tap...
More details would have been helpful, such as mentioning the tap design (traditional or quarter turn type?) and when the hammering noise happens?
Hammering is often caused by a worn tap. When turned partly on the jumper can vibrate and cause the pressure in the pipe to fluctuate and magnify the noise, especially when there is a long run of pipe that is inadequately clipped to the wall...
Plumbing | Answered on Jun 06, 2020
OPEN A FAUCET IN THE KITCHEN AND WAIT IF WATER COMES THEN YOU HAVE NO PROBLEM MY GUESS IS THERE IS TOO MUCH AIR PRESSURE IN THE TANK . IF YOU HAVE AN ELECTRIC WATER HEATER YOU HAVE ALREADY BURNT THE ELEMENTS OUT IN IT
Plumbing | Answered on May 26, 2020
How to Remove the Sprayer on a Moen 7900 Faucet
  1. Turn off the valves under the sink by rotating the valve handles counterclockwise.
  2. Hold the hose in one hand and push upward on the hydrolock connection with the other to disconnect the sprayer from the diverter. ...
  3. Pull the sprayer straight upward and out of the guide.
https://homeguides.sfgate.com/remove-sprayer-moen-7900-faucet-83422.html
Plumbing | Answered on May 19, 2020
Honda Horizontal OHV Engine for Non Pumps  160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2 Logo
7 questions posted
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
ray gallant
Renee Knafel-Bullock
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Honda Plumbing
  • Honda Plumbing
Most Popular Question
psi gx 160 engine single chamber
  • Plumbing
