20 Most Recent Sharp AQUOS 60" 650 Series LED HDTV - LC60LE650U Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Sharp AQUOS 60"... | Answered on Jan 20, 2016
spec sheet here
http://files.sharp.ca/Downloads/ForHome/HomeEntertainment/LCDTVs/SpecSheets/LE650_SERIES/LE650%20Series_Spec_Sheet_rev.pdf
It does have a Sleep Timer as most do. Not many people want the television to switch on when they are not at home?
Direct Button Operation
INPUT .......................................................... 20
Changing Channels ...................................... 20
Changing Volume ......................................... 20
MUTE........................................................... 20
Sleep Timer .................................................. 20
manual is here
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/mon_man_LC70LE640U_LC60LE640U_LC52LE640U_LC70C6400U_LC60C6400U_LC52C6400U_LC80LE633U.pdf
Sharp AQUOS 60"... | Answered on Sep 22, 2015
No signal is being detected at the antenna input.
Sharp Aquos... | Answered on Aug 14, 2020
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Sharp Aquos... | Answered on Dec 30, 2019
We have the same TV. In settings for sound you need to select the port directing where you want sound to play. It may be that it is currently setup to play to a sound bar.
Sharp Aquos... | Answered on Oct 06, 2019
The replacement power board may have failed, possibly due to some other failure condition.
Sharp Aquos... | Answered on Mar 07, 2019
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sharp Aquos... | Answered on Jan 06, 2019
Sharp AQUOS 60" 650 Series LED HDTV - LC60LE650U Logo
2 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
half screen darker other ve seen
  • Televison & Video
