20 Most Recent Weller Portasol Pro Cordless Butane Soldering Iron Kit Questions & Answers
Due to the lack of detail provided, there are certain assumptions that must be made. These assumptions may or may not address the specifics of your problem as described. Please don't take anything I state in a derogatory way.
Standard operations.
These devices use very little fuel, with a single charge lasting about two hours.
After they are warmed up, the only visible evidence they are functioning is the dim red glow at the vents behind the tip.
Firing it up.
I'm assuming it has fuel in it.
When you try to fire it up, I'm assuming it is turned on and you can hear fuel being released.
The Super-pro models have a built-in igniter, otherwise using a lighter or a spark, ignite the gas at the vents behind the tip
A yellow flame can appear for a few moments until the unit heats up. It will quickly subside to a smoldering red glow.
It will take a few minutes for the tip to become hot enough to use.
That is about it,
Best regards
Mike
Weller Portasol... • Answered on Jul 25, 2017
I have the same soldering iron and have found for this problem, the replaceable tip has worn out.All you need to do is buy a replaceable tip of your choice. The tips are a consumable part that wears out.
It is supposed to produce heat there, it's the place where catalytic combustion takes place. If the tip doesn't heat up enough, it means that either the tip is not screwed properly into the housing, or there's not enough gas pressure. The catalytic mesh should be orange in color when heated properly.
Too low gas pressure may be a result of many things, like a malfunctioning valve (regulator and/or on/off),or clogging of the ceramic pressure reductor due to poor quality gas used, with high heavy fraction content.
Weller Portasol... • Answered on Jul 15, 2010
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Weller Welding... • Answered on Jun 28, 2019
Sounds like main transformer is bad or bad connection. Unplug it and take it apart and check for loose connections. Good luck.
Weller Welding... • Answered on Jun 16, 2019
Weller Portasol Pro Cordless Butane Soldering Iron Kit Logo
Popular Tags
16 questions posted
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Weller Welding Tools
Most Popular Question
weller psi 100k doesnt ignite
  • Welding Tools
