20 Most Recent Cooper Tire Rubber Weller Soldering Iron Heavy Duty WSP150 150W 24V Questions & Answers
wires in lead to the handle may be broken
Welding Tools | Answered on Jul 11, 2020
the 8 setting nob is for what?
Welding Tools | Answered on May 31, 2020
It is possible to contact a vendor online:
https://www.wlenk.com/contact.php
Welding Tools | Answered on May 28, 2020
The correct current, or amperage, setting primarily depends on the diameter and type of electrode selected. For example, a 1/8-inch 6010 rod runs well from 75 to 125 amps, while a 5/32-inch 7018 rod welds at currents up to 220 amps. The side of the electrode box usually indicates operating ranges. Select an amperage based on the material thickness, welding position (about 15 percent less heat for overhead work compared to a flat weld) and observation of the finished weld. Most new welding machines have a permanent label that recommends amperage settings for a variety of electrodes and material thicknesses.
https://welderreview.com/yeswelder-15ft-250a-mig-welding/
Welding Tools | Answered on Apr 02, 2020
https://www.airgas.com/?s_kwcid=AL!10136!3!372572965137!b!!g!!%2Bwelding%20%2Bparts%20%2Bchicago&utm_arg=SEM:Google:SEM%20NB%20Local%20-%20Midwest:SEM%20NB%20Local%20-%20Midwest%20-%20Welding%20Parts%20-%20MBM:Search:372572965137:Local:Local::%2Bwelding%20%2Bparts%20%2Bchicago:b:Acquisition&gclid=EAIaIQobChMItKP_2q3C6AIVQtHeCh2qXwBGEAAYASAAEgLRkfD_BwE
Welding Tools | Answered on Mar 30, 2020
https://www.youtube.com/watch?v=_yTnfRS9B04
So, for gasless MIG welding polarity (when using flux core wire), your MIG welding polarity settings should be set to direct current electrode negative (or DCEN). With DCEN, the negative terminal inside your machine is hooked up to your electrode (your MIG gun) while the positive terminal is hooked up to your ground.
https://makemoneywelding.com/how-to-set-your-mig-welding-polarity-settings/
Welding Tools | Answered on Mar 22, 2020
Tip
What are 4 common welding processes?
There are four common welding processes utilized through out the work industry today. They are :
(Stick Welding or SMAW) Shield Metal Arc Welding
(Mig Welding or GMAW) Gas Metal Arc Welding
(Tig Welding or TMAW) Tungsten Metal Arc Welding
(FCAW) Flux Cored Arc Welding
There are many many welding processes, however these are the most common. The type I am going to discuss briefly today is SMAW. The most economical and cheapest way to learn if welding is for you or not is to start with stick welding. It has the least amount of variables that can go wrong for a beginner. It is not fast paced like mig or flux core, so you have time to watch the molten puddle to see what it is doing and make necessary adjustments to correct the size, shape, and contour of your weld bead. The hardest part for a beginner is to keep the electrode from sticking to the work piece. Thus is the reason it got the name of "stick welding". There are three common ways to strike an arc in SMAW. Tap Start, Scratch Start, and the last is to place the electrode upon your fingers like a pool cue, and shoot the rod like your playing pool.
on Mar 20, 2020 | Welding Tools
https://www.youtube.com/watch?v=olxa_LDyi_I
Welding Tools | Answered on Jan 28, 2020
Chemical Earthing Electrodes help in meeting all kinds of earthing and grounding needs for industrial and residential purposes.
Gmax Chemical Earthing Electrode consists of the main earth electrode encapsulated within another pipe filled with highly conductive compound. gmax main earth electrode thus protected by the presence of the conductive compound and the outer pipe last beyond a normal GI pipe electrode. Highly conductive property of the compound facilitates the fault current to immediately discharge through the outer pipe to the surrounding area.
Gmax whole assembly of the Chemical Earthing Electrode is then installed in a bore made in the earth and the space around is filled by scientifically developed earth enhancing compound.
With an increase proportion of technology, we are manufacturing and supplying Chemical Earthing Electrode.
Specifications:
Lengths OD ISI GI ISI GI Pipe Technical Details Outer Pipe Thickness Inner Pipe Thickness Outer Inner Copper Terminal 3.0 meter 300 cm x 90 mm 40 mm 50 mm x 6 mm 14 gauge 12 gauge 2.0 meter 200 cm x 90 mm 40 mm 50 mm x 6 mm 14 gauge 12 gauge 1.5 meter 150 cm x 90 mm 40 mm 50 mm x 6 mm 14 gauge 12 gauge 1.0 meter 100 cm x 50 mm 25 mm 25 mm x 3 mm 14 gauge 12 gauge
GMAX Chemical Gel Earthing Electrode: GMAX Leveraging on our years of industry experience, we are instrumental in manufacturing and supplying Chemical Gel Earthing Electrode. Offered electrode is used for earthing owing to its excellent electric conductivity and durability. We used only quality-approved raw materials to manufacture these electrodes so as to make these suitable for use in commercial or residential areas. We properly check offered Chemical Gel Earthing Electrode on different quality parameters to remove any kind of defect.
Product Attributes:
  1. Highly reliable for safety of human life
  2. High load carrying capacity
  3. Maintain low resistance value
  4. Maintenance free and corrosion free
  5. Available in different specifications
  6. Easy installation and longer service life
  7. Low thermal insulation and high conductivity
  8. Protect from voltage breakdown or leakage current
Cooper Tire  Rubber Weller Soldering Iron Heavy Duty WSP150 150W 24V Logo
1 questions posted
Top Cooper Welding Tools Experts
Bill Boyd
ray gallant
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Cooper Welding Tools
Most Popular Question
solder tip worn out need replace remove
  • Welding Tools
