20 Most Recent
Blaupunkt RPD-545 CD Player Questions & Answers
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
6/22/2012 9:33:12 PM •
Blaupunkt...
Answered
on Jun 22, 2012
Cannot get the memory to
Very simple solution. What you need to do is remove the unit and swap your RED (ignition) wire with your YELLOW (constant or battery) wire.
there is not much more to it than that. if you provide me with your vehicals details i can give you a complete wiring diagram.
hope i helped and please dont forget to rate my solution
cheers
5/20/2012 9:59:27 AM •
Blaupunkt...
Answered
on May 20, 2012
NO CD
Ok im not to familiar about this head unit but some have a little hole where you can use a paperclip to reset it.. if you cant see one Take the negative terminal off the battery and keep it for for a minute or so...this will reset your deck and hopefully the deck will see it has a cd in it.
Another thing you can try is to push a cd in like you normally would but when it starts to suck it pull it out and then it will think it loaded...that also worked for me in the past.
3/28/2007 6:06:01 AM •
Blaupunkt...
Answered
on Mar 28, 2007
