20 Most Recent Toro Lawnmower 20099 Mower Mowers Lawn Questions & Answers
arrow alway on most bikes points at the exhaust or outlet side
Toro Lawnmower... | Answered on May 24, 2019
Hi Kohler plug (14 13203-S) or genuine OEM #14 132 03-S if u cross reference RJ19LM THERE R 20 REPLACEMENT plugs CHEERS
Toro Lawnmower... | Answered on Jun 01, 2016
Could be the valve in the carby. Had a similar problem with my Victa. Have a look on the internet for briggs and Stratton engine carby service. It was really helpful. Your carby may be different but the info I found was very helpful and explains how the power valve operates and what to do to prevent surges and power loss.
Toro Lawnmower... | Answered on Sep 18, 2015
Have you ever oiled all the little working parts on your mower? The adjusters also get dry and they rust up or just get dirty. You can try to oil all the areas that move on the height adjusters and see what happens.
Toro Lawnmower... | Answered on May 03, 2015
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Toro Lawnmower... | Answered on Aug 16, 2014
it has an electromagnetic clutch switch on it,that is more than likely bad. Try this,pull the pto switch out and start the engine,then disconnect the 2 wires coming from the switch and just tap them together and see if they will come on. If they do then you need to replace that switch.
Toro Lawnmower... | Answered on Jul 28, 2014
Usually it is easiest to pull the bolt, washers, and spacer that hols on the idler pulley. The only items are belt guides if so equipped.
Toro Lawnmower... | Answered on Jul 06, 2014
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Toro Lawnmower... | Answered on Jun 06, 2014
Could be several things. Starter sol hooked up wrong, key switch bad... well ok thats pretty much it, check those things then see what happens.
Toro Lawnmower... | Answered on Dec 24, 2013
There could be a whole bunch of things to cause this, from a badly worn engine to just a valve stuck open, a dealer could do a leakdown test on the engine and give a more definate reason for the problem, or you could remove the cylinder head ( side valve engine ) and check the valves are opening whilst turning the engine.
Toro Lawnmower... | Answered on Aug 03, 2013
Toro Lawnmower 20099 Mower Mowers Lawn Logo
84 questions posted
Top Toro Garden Experts
roeb
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
no compression when pull cord
  • Garden
