20 Most Recent Stanley Proto Stanley xp180 Cross Line Laser Level Questions & Answers
It is a good laser, but it is self leveling so you will have trouble setting it on the floor and be able to title it. It will probably go into error mode and the laser will flash telling you that it isn't level.
Suggest a step ladder that is about the right height.
Stanley Proto... | Answered on Jul 16, 2011
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
Measuring Tools... | Answered on Oct 21, 2020
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Measuring Tools... | Answered on Aug 02, 2020
Those are precision devices and require factory check up and calibration at regular intervals. Contact your dealer.
Measuring Tools... | Answered on Aug 01, 2020
Reset display by pressing the RESET button, located on the back of the display unit inside the battery compartment. Date and time will need to be entered after a reset. Flashing of the outdoor temperature is generally an indication of wireless interference.
https://www.acurite.com/media/manuals/00754-instructions.pdf
Hard Reset:
  1. Bring both the sensor and display unit together and power down by removing at least one battery from each and/or removing the power cord.
  2. Make sure the A-B-C switch on both units matches. ...
  3. Reinstall the battery in the outdoor sensor.
  4. Reinstall batteries and/or power cord into the display unit
https://support.acurite.com/hc/en-us/articles/360013641694-3-in-1-Reset
Measuring Tools... | Answered on Apr 29, 2020
You may use following removals Tools
  • Moving Dollies
  • Pallet jacks
  • Hand Trucks
  • Hydraulic Tools
You may also get information about Removals Tools Here
Removal Companies Tools
Measuring Tools... | Answered on Apr 24, 2020
https://support.acurite.com/hc/en-us/articles/360007555574-Temperature-is-Flashing-Stuck-or-Showing-Dashes-on-a-Basic-Multi-Sensor-Display-
Measuring Tools... | Answered on Apr 22, 2020
Take it apart and get some isopropyl alcohol and a q-tip. check for corrosion around the terminals. If there is none, look for loose connections. If there is something loose, check if a bit of the board is loose. If a bit of the board is stuck to the terminals, give up on batteries.
I do not believe that you can buy these separately. They are factory programmed and paired together.
Measuring Tools... | Answered on Apr 09, 2020
Stanley Proto Stanley xp180 Cross Line Laser Level Logo
2 questions posted
Top Stanley Proto Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Stanley Proto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Proto Measuring Tools & Sensors
Most Popular Question
use xp180
  • Measuring Tools & Sensors
