20 Most Recent Olympus DS-330 Digital Voice Recorder Questions & Answers
Swapped out the USB cable with a different one and the display showed, "REMOTE". Hope this helps someone out. I've been troubleshooting this on my end for the last two days...
Olympus DS-330... | Answered on Apr 22, 2020
Download your driver from here driverupdate us . Download the software (for free), scan for the required driver and update, It will take 2 mins. Hope this was helpful. cheers
Olympus DS-330... | Answered on Nov 24, 2014
If you are using dss player lite, it does not support downloading. It is only a player. If you have Player for Mac version 1, you need to update to version 6. It can be found here.
Olympus DS-330... | Answered on Dec 21, 2013
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Olympus DS-330... | Answered on Jun 08, 2013
You will need to format the memory. In the menu, scroll to format. All recordings will be erased.
Tom
Olympus DS-330... | Answered on Nov 24, 2011
There is no factory reset but you can reformat the memory. Hold the menu button, scroll to format, press record and follow display instructions.
Olympus DS-330... | Answered on Oct 10, 2011
Try going into the BIOS (or CMOS) of your computer and look for
Legacy USB Enabled/Disabled
If it is set to Enabled, set it to Disabled
If it is set to Disabled, set it to Enabled
This sometimes fixes these kind of problems.
Hope this helps.
Olympus DS-330... | Answered on Sep 14, 2011
The serial number is located on a sticker in the battery compartment.
Olympus DS-330... | Answered on Jun 26, 2011
Software downloads are available at www.olympusamerica.com or you can contact them at 1-888-553-4448.
Olympus DS-330... | Answered on Mar 07, 2011
Contact Olympus at 1-888-553-4448.
Olympus DS-330... | Answered on Feb 12, 2011
8360-0101-0000-7253-9834
Olympus DS-330... | Answered on Feb 10, 2011
Olympus DS-330 Digital Voice Recorder Logo
42 questions posted
Top Olympus Audio Players & Recorders Experts
Lee Hodgson
Lee Hodgson
Edward Easley
Edward Easley
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
will the ds 330 software work with windo
  • Audio Players & Recorders
