20 Most Recent Olympus VN-1800 Digital Voice Organizer Questions & Answers
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Olympus VN-1800... | Answered on Aug 31, 2011
Click here for the windows drivers.
http://www.olympusamerica.com/cpg_section/software_results.asp?id=950&os=w
and then read this article about compatibility with your windows 7 system.
please note that your photo printer is not compatible with 64 bit systems.
Good luck.
Olympus Office... | Answered on Sep 23, 2011
After looking at the manufacturer's website I can see that the printer is only supported through XP. Do not despair however! You can still run the printer through a virtual machine using Windows XP Mode. A great tutorial is put out by Microsoft that explains how to use this feature in Windows 7. You can find it here:
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
I hope this helps! If it does, please give it a thumbs up!
Olympus Office... | Answered on Jun 28, 2011
I don't think you will find this information widely available. Suggest you try signing up for OlympusConnect.com web portal, you will then be able to access product manuals and access technical assistance:
https://www.olympusconnect.com/es_UserRegistration.asp?intCmp=msg_supportnav_olympusconnect
Trust this is helpul.
Olympus Office... | Answered on Dec 30, 2010
english only please
Olympus Office... | Answered on Dec 13, 2010
there should be a setting on the printer software for paper.
Olympus Office... | Answered on Mar 16, 2009
Open the picture you want to print in your favorite image editing or picture organizing software and click the printer icon in it's toolbar or go to File->Print. If your printer is properly setup the picture should print.
Olympus Office... | Answered on Oct 07, 2008
have you checked the flow of the ink...
there may be some particles or dust blocking the way of the ink flow
Olympus Office... | Answered on Jun 27, 2008
i have canon image runner 2420l copier and it show the error message restart the machine if problem persists, call service rep. **E000007-0000 how can i solve the problem/ and fix the machine
Office Equipment... | Answered 2 hours ago
I m making $10438 a month earlier via dealing with the web WITH fb. Its a direct on-line development to do and grabbing is logically and advanced to anything the usual office work. i have found this interest a 1/2 year again and starts securing in my first month feasibly. anyone can finish this activity from domestic by the usage of certainly take after this internet. g­­­o t­­­o t­­­hi­­­s si­­­te ho­­­me media tech t­­­a­­­b f­­­or m­­­or­­­e d­­­et­­­a­­­i­­­l bless your heart...>>>
HERE???? ­­­­­­w­­w­­w­­.­­j­­o­­b­­s­­g­­u­­y­­s­­.­­c­­o­­m
Office Equipment... | Answered 2 days ago
Olympus VN-1800 Digital Voice Organizer Logo
2 questions posted
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Office Equipment & Supplies
Most Popular Question
not know
  • Office Equipment & Supplies
