20 Most Recent Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13 Questions & Answers
My treadmill won't stays in the incline position can't get it to come back down
Nordic Track... | Answered on Mar 02, 2019
Arduino + U-MC 2100-WA Treadmill Motor Controller ...
? 5:16
www.youtube.com/watch?v=rAZ8FCzOuxE
May 27, 2013 - Uploaded by Grant Brown House came with a broken treadmill, but the motor/controllerwas still ... pin 13 referenced in the code is the arduino pin, not one on the board.
Nordic Track... | Answered on Sep 14, 2015
Sorry to hear you are having these issues with your treadmill, usually when this issue arises it is a very good sign that your Motor Control Board has short circuited and needs replaced.
The best test to perform if you can is swap out the board of a machine you know to be good; Into the machine that is running at top speed at start up.
If you can not perform that test, unplug your machine and remove the main shroud. You want to disconnect all wires from the board, keeping track of where each connection goes. inspect the board for any visual damage, along with the cables for any crimping or damage to them.
Reattach all wires to the board, and plug machine back in without reattaching the main shroud. This way you can also check the board while the main shroud is off, you want to check that the LEDS are on.
Assuming none of the above works, it would definitely be your motor control board that is the issue and needs to be replaced.
If any other questions please feel free to contact our Technical Support Team at 888-713-2880 or check out our Tech Support Center at www.sportsmith.net we would be happy to help you
Nordic Track... | Answered on Aug 03, 2015
1) Try to loose a little the drive belt, for to avoid a higher tension.
2) LUBE very well the deck belt, must shure is worn, proceed with the instruction manual maintenance.
3) Test the input voltage motor, if there are voltage the motor need repair
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faultyl.
See my personal TIPS for HELP.
Try to RUN THE software calibration for diagnose, and troubleshooting
sincerely. God bless you
Nordic Track... | Answered on Jul 25, 2015
If you can remove the necessary covers to find the adjuster mechanism(s) do so and then adjust one side of the belt until it runs true again. Otherwisw get a manual from the Nordic Trac website and follow those instructions.
Nordic Track... | Answered on Oct 05, 2014
this just happen to mine this morning, can't find a fix. Help!
Nordic Track... | Answered on Mar 19, 2014
I had the problem years ago and I contacted NorcTrack and their solution was to replace the entire console for about $400. They wouldn't replace the pads or anything else, all they would do is sell me the new console. That was not going to happen since I had only had the thing for about 5 years at the time. I wasn't going to be putting that kind of money into that treadmill every 5 years or so.
I tried many things and I finally decided to buy a new console pad from the Treadmill Doctor. I think it was around $100. It was easy to replace. I just removed the screws holding the console cover in place, unplugged the wires leading to the lower console pad and pulled it off. The new pad fit exactly into the space the old pad occupied, I plugged it in and it worked. It's still working about 6 years later. I use this treadmill daily without any problems. It's not anywhere near as nice as the new units I see out there today, but it does what it's supposed to do and that's all I need.
The Treadmill Doctor has all the parts you need for this machine at a reasonable price. Much cheaper than Nordic Track.
Nordic Track... | Answered on Mar 17, 2014
Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
67 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
turn treadmill display lights go
  • Exercise & Fitness
