1) change the batteries by news one2) clean the contacts batteries very well3) tight the ribbon cables from keypads from display board.4) tight the wires connector from display board vs lower board5) Adjust the reed switch see the diagram, clean it and tight the wire connector well.6) After you fix it RUN the software calibration for diagnose , troubleshooting and fix it.God bless you
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated. - unplug, turn off, and take the key out- plug machine in- turn switch on- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY- let go of both buttons- press STOP 1 time- pres INCLINE UP 1 time- this should reset it. The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
1) replace old batteries with alkaline2) clean the contacts baterries very well3)tight the ribbon cable for keypads inside from display board and clean it the ribbon cable.4)Adjut the REED swithc, clean it, test for open or faulty, and tight the connector. see the diagram attached.God bless you
1) LUBE the deck belt see the video 2) Lube the rollers bearing front and rear 3) test the drive belt motor and replace it 4) Deck belt wornGod bless you
