20 Most Recent Nordic Track NordicTrack Elite 9500 PRO Treadmill Questions & Answers
Had the same problem ...it seems my list of problems is growing not getting shorter....it's been two weeks and the thing still isn't running yet becasue the calibrate system fails, wifi is connected but no internet , speakers hum, ..this small system runs android but it runs so SLOW......even the latch bar couldn't be installed because the hole underneath was too small for the screw to go thru....
Nordic Track... | Answered on Mar 29, 2019
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Nordic Track... | Answered on Jun 26, 2016
see the video and lube the deck belt+rollers bearing. You must do it every 150miles aprox.
God bless you
Nordic Track... | Answered on Jan 21, 2013
Please in the section open connections network give to repair, and the system will repair.
If the problem persist reboot the Modem-wireless router again, and see if the signal is coming more Strong.
Reset the Modem in the small hole, with some pencil introduce the pen and reset it
Retigh the wires coming from your Modem Wireless router. And finally Test again if is working. sincerely.
Nordic Track... | Answered on Dec 01, 2011
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Nordic Track... | Answered on Nov 30, 2011
    proper grounding the machine mite help. the frames are powder coated and they dont remove enough paint for a good ground point chek and make better contactwith frame
    Nordic Track... | Answered on Feb 28, 2011
    The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
    One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
    Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
    Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
    Nordic Track... | Answered on May 24, 2010
    https://www.audiusa.com/content/dam/audiusa/brochures/2019/2019_Audi_Q7_QSG.pdf
    Nordic Track... | Answered on Apr 10, 2020
    Nordic Track NordicTrack Elite 9500 PRO Treadmill Logo
    25 questions posted
    Top Nordic Track Exercise & Fitness Experts
    Marvin
    Marvin
    Jesse Garza
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
    View Most Popular
    • Nordic Track Exercise & Fitness
    Most Popular Question
    updated firmware now all get
    • Exercise & Fitness
