20 Most Recent American Standard Kitchen Faucets. Fairbury Single-Handle Pull-Down Questions & Answers
tighten the retain nut mounted under sink.
American... | Answered on May 02, 2018
American Standard has the Installation Guide for some of their kitchen faucets on each product's page. A list of some of their two-handle kitchen faucets is available here: https://www.americanstandard-us.com/kitchens/kitchen-faucets?No.%20of%20Handles=Two&page=1&plimit=21 . Home Depot has the Installation Guide for the Heritage wall-mount faucet with Goose Neck spout on the product page: https://www.homedepot.com/p/American-Standard-Heritage-2-Handle-Wall-Mount-Kitchen-Faucet-in-Polished-Chrome-with-Gooseneck-Spout-7293-252-002/100080273 . The current link to the guide is https://images.homedepot-static.com/catalog/pdfimages/de/deca2fce-73fc-47a2-acb5-efc7232dac17.pdf .
These are standard plumbing installation guides. They condense most of the steps of the hardware install into one diagram/step of the guide.
I hope this helps. If you need further assistance, please add more information on the style of your faucet. (Is it a wall-mounted faucet or a sink-mounted faucet?)
American... | Answered on Aug 06, 2020
Download the BILT app and search for your faucet model. The icon is turquoise with a white nut ( as in nut and bolt).
It will show you step by step nearly everything under the sun. Hope that helps a bit.
American... | Answered on Nov 09, 2019
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
American... | Answered on Dec 10, 2018
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
American... | Answered on Nov 27, 2018
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
American... | Answered on Sep 27, 2018
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
American... | Answered on Apr 13, 2018
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
American... | Answered on Jan 12, 2018
I would google it . Or look on u tube
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
American... | Answered on Sep 13, 2017
American Standard Kitchen Faucets. Fairbury Single-Handle Pull-Down Logo
1 questions posted
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Plumbing
Most Popular Question
fixing fairbury faucet goose neck loose
  • Plumbing
