20 Most Recent
ARP 2344314 234-4314 Head Stud/bolt Kits Questions & Answers
My 13" General International thickness planer won't turn on. I tried the reset button and still no luck. I
replaced the switch and this didn't work. Any suggestions?
With the cheapest multimeters costing as little as just a few dollars there is no reason not to have the ability to check things instead of guessing.
With most portable tools and appliances the first thing to check is the power cord because around 60% of the time an internal break is the cause of a tool not starting.
Power tools and appliances often have electronics to provide variable speed or soft start. Checking these is beyond the scope of the home repairer but a multimeter can check continuity to any electronic component and from it to the motor and the ensure there is continuity through the motor.
If everything else is ok the fault is probably with the electronics if there is any. If you are feeling really brave, the final test is to temporarily and safely bypass the suspected component and apply power.
8/10/2020 3:10:31 PM •
Cutter Tools
Answered
on Aug 10, 2020
Are bolt cutter blades really sharp?
Manual bolt cutters usually have symmetrical V-edge cutting blades.
With the sharpening angle in the range of 20-30 degrees.
For comparison, the sharpening angle of the kitchen knife is less than 10 degrees. With such a pretty blunt edge is impossible to cut your finger. But this is the best option for cutting thick metal rods or cables. Like this:
If it is interesting to read more information about bolt cutters, I recommend this review -
https://toolslaboratory.com/best-bolt-cutter-buyers-guide-2019
7/10/2019 6:57:37 AM •
Cutter Tools
Answered
on Jul 10, 2019
How to Use a Pipe Cutter?
Pipe cutters are really useful tools that can be used in the house to cut pipes that are made from metal or plastic. You could always try using a saw of some kind but pipe cutters will give you a much straighter edge.
Here are some basic instructions to help you successfully use a pipe cutter.
1. Decide exactly where on the pipe you would like to make a cut.
2. Loosen the handle on the pipe cutter and place it around the pipe.
3. Now tighten the cutter until the blade is in contact with the pipe.
4. Turn the pipe cutter a few turns around the pipe and it will score a line into the pipe.
5. Keep turning the pipe cutter around until you've cut the pipe off.
6. In order to create a nice straight edge inside the cut pipe you need to take the bottom blade out of the pipe cutter.
7. Place it into the cut end of the pipe and turn it around a few times until it's nice and smooth.
