20 Most Recent
Timex 1440 53591 Sports Quotient Wristwatch Questions & Answers
To set time on my timex wrist watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a
PDF version of your instruction manual.
Hope this tip helps
R/
David
I just bought a Paul
So I figured out how to set the date and time on this watch. Hold the "C" button down until the alarm setting starts flashing, the hit the "C" key again to get the date setting. Once the date is flashing, hit the +/= key to select month, date, etc. Than hit any other key to change the number.
Time is on military time. want to switch to
If you have the manual then it should explain how to change from "24" to "12" display.
If you haven't got the manual then some experimenting my find the solution to your problem. One of the buttons should cycle through the settings menu and in there should be an option to set the display.
Day of the week
Switch the watch into 24 hour mode - should be a simple task - while in normal time mode, press one of the buttons other than light, mode or set button - which I'm guessing leaves only one.
I'm guessing that the watch does not show am / pm?
By putting in 24 hour mode, should be easy to get the right day at midnight changeover.
Hope this helps.
Setting the time
hello,push and hold the mode button for 3 seconds,then push the mode button one more time and now your at time change.
the st/stop button changes to the seconds,minutes and then hours,the lap/reset button changes the numbers.when your finished push the mode button and your done.
Trouble with setting date.
hello,to set the date:
push and hold the mode button for 3 seconds,then push the mode 1 time it will take you to the time,press the st/stop 3x's to reach the month,use the lap/reset button to change,4x's to reach the date,use the lap/reset button to change,5x's changes the day of the week,use the lap/reset button to change.when yor done push the mode button to set.
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
I cant Change it!!!
hello,to switch back and forth from 12 to 24hrs.:
push and hold lap/reset button and push the mode button,
an (A) will appear meaning it's in the 12hr zone,no (A) means 24hr.mode.
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads
timex.cahttps://www.timex.ca
Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers.
Rating for timex.ca: 3.7 - 209 reviews
- Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex
https://www.timex.ca > watch-manuals
Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz
https://manualzz.com > Fashion & style > Watches
View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
