20 Most Recent Onkyo DV-CP500 Multi-disc DVD Player Questions & Answers
3answers
Re: Onkyo DV-CP500 DVD player stuck in standby mode (by 7 users)
Hi Yes, sorry just saw this comment. Swap out C7, C17 and C18 in the power supply. Also I would check if you are getting 9Volts to the motor control IC's pin 7 coming off of C005 on the Mechanism Board which is under the unit. The hole for the C005 cap was drilled into a very narrow section of the circuit board and has marginal connection at best.. mine stopped working because of this 6 months after I fixed the power supply.
8/4/2014 9:23:46 PM • Onkyo DV-CP500... • Answered on Aug 04, 2014
0answers
DISC ERROR
I'am afraid you have done everything possible, the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to replace.
4/23/2012 12:38:49 AM • Onkyo DV-CP500... • Answered on Apr 23, 2012
I'm creating a dvd movie from my flip videos
VOB video file (.VOB), or AVI or Mpeg-1. These are the file type it can play.
Good luck.
8/26/2011 5:00:41 PM • Onkyo DV-CP500... • Answered on Aug 26, 2011
Onkyo cp500 standby light blinking not turning on
Seems like a manufacturing defect with the way C005 on the Mechanism Control Board was mounted. The positive lead hole on the circuit board for this electrolytic capacitor was drilled into a land that was too narrow for the lead size. The result is no +B to the motor control IC's(LB1641's) on this board. Jumper with a suitable wire from the positive lead on C005 to pin 7 or 8 of the LB1641. This fix obviously assume you know how to take the unit apart (really very simple really if you look at the unit carefully). The board is accessible underneath the entire mechanism.
4/12/2009 5:12:27 PM • Onkyo DV-CP500... • Answered on Apr 12, 2009
Plays MP3 files at high speed
Try newest firmware. It should work for all Onkyo DVD-players:
http://gamerlamers.com/Onkyo_DV-SP1000_firmware_update/
Regards
Svein
2/27/2008 8:00:12 PM • Onkyo DV-CP500... • Answered on Feb 27, 2008
I need to know if the Onkyo receiver I currently have is going to work with 4k Ultra HD TV
You need to post the model number of the Onkyo so we at Fixya can look it up.
2/25/2024 6:21:04 PM • Onkyo Televison... • Answered on Feb 25, 2024
How to reset an Onkyo RC-834M remote please?
@P D Why tag to an 11 year old question? It is 2024, no one uses Universal Remotes. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote Samsung TV remote codes list 4-digit codes 4-digit codes 5-digit codes 6 more rows • Dec 7, 2023
Samsung TV universal remote codes - explained - PC Guide
2/17/2024 7:59:40 PM • Onkyo Televison... • Answered on Feb 17, 2024
Tengo un control onkyo RC 880M lo puedo programar para un reciver paramax p512
No, no es posible. Solo frecuencia ?nica ..
8/4/2023 8:38:01 PM • Onkyo Televison... • Answered on Aug 04, 2023
2answers
I have a onkyo TX-SR602 stereo and I got a replacement original rc-590m remote for it but I can figure out how to get it to pair to the receiver. I need to know how to reset it and the receiver
Hi, if you need to factory reset, there might be a small hole in your remote that you can use a pin to press into. This helps to factory reset some devices. The hole might have something like "reset" written by it. Thank you.
10/8/2022 3:06:10 AM • Onkyo Televison... • Answered on Oct 08, 2022
I have an Onkyo TX-NR545 receiver. No sound.
Make sure your on internal speakers, it can be found in menu sound options
9/25/2021 1:01:18 PM • Onkyo Televison... • Answered on Sep 25, 2021
Onkyo TX SR-605 powers off after long use/sitting plugged in but off.
This is either a weak solder connection that gets warm and looses its connection or it is a capacitor that is failing. Both require some knowledge of electronics to find and repair.
6/24/2021 2:37:07 AM • Onkyo Televison... • Answered on Jun 24, 2021
2answers
I have an Onkyo DV-CP702 DVD changer. The remote stopped working, I've tried two remotes. I imagine I'll need to replace the IR sensor in the player...any ideas?
Hello Chris, did you test if the remote cotroles emit? to test take the cell phone, put it in camera mode and point the transmitter of the remote control at the camera and press the buttons, every time you press you should see a light on the transmitter of the remote control, if you do not see it, the remote control, it does not work There would be another test to perform, only if you have an Onkio Receiver, with control output on the back panel, if you have it, you have to place a 3.5 mm Miniplug cable to the 3.5 mm Miniplug, from the DVD player to the the Receiver, this can be seen on page 19 of the user manual of your Onkyo DV-CP702 DVD, with this connection you use the remote control of the Receiver to control the DVD I hope you can solve the problem Greetings Franco Dosil Hola Chris, probo si los cotroles remotos emiten? para probar tome el celular, pongalo en modo camara y apunte el emisor del control remoto a la camara y presione los botones, cada vez que presione tendria que ver una luz en el emisor del control remoto, si no la ve, el control remoto, no funciona Habria otra prueba para realizar, solamente si usted tiene un Receiver Onkio, con salida de control en el panel posterior, si lo tiene, tiene que colocar un cable Miniplug 3,5 mm a Miniplug 3,5 mm, desde el reproductor de DVD hasta el Receiver, esto lo puede ver en la pagina 19 del manual de usuario de su Onkyo DV-CP702 DVD, con esta conexion usa el control remoto del Receiver para controlar el DVD Espero que pueda solucionar el problema Saludos Franco Dosil https://www.intl.onkyo.com/downloads/manuals/pdf/dv-cp702_manual_e.pdf
5/21/2019 1:49:04 AM • Onkyo Televison... • Answered on May 21, 2019
2answers
How do I take apart an Onkyo RC-693M remote control? I removed the four T6 screws, but can seem to get the back off..
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean].
2/7/2019 8:17:20 PM • Onkyo Televison... • Answered on Feb 07, 2019
Onkyo DV-CP500 Multi-disc DVD Player Logo
Popular Tags
14 questions posted
Top Onkyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Televison & Video
Most Popular Question
disc error
  • Televison & Video
