20 Most Recent Onkyo M-282 2-Channel Amplifier Questions & Answers
Can I ask you something? I have the same but the remote doesn't work, and I have no sound in the B speakers. I wonder if there's something that I have to do with the remote, or there's a problem with the receiver, Thanks.
Onkyo M-282... • Answered on Feb 28, 2021
disconnect power and try after 20min without speakers.
Onkyo M-282... • Answered on Aug 08, 2017
Likely you blew your outputs Transistors or mos fets, you cannot be sure without ohm meter. usually when one side goes out the protection kick in on both chanels Tony Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Onkyo M-282... • Answered on Jun 08, 2017
If your speakers are not in good condition you may have floated the cones inducing DC feedback into the amplifier, Im not sure if this amp has internal protection fuses, but I would check them and if so replace with same specification fuses. Sometimes we get lucky... Good luck
Onkyo M-282... • Answered on Apr 23, 2011
If you have the old fuse, it should be either a 3AG style or GMA style. Look at any of the on-line electronics parts suppliers for these. You can verify the type based upon what is written on the fuse itself. If you have further questions, post any markings on the current fuse here and I'll explain further.
Dan
Onkyo M-282... • Answered on Feb 18, 2011
you can't get 2 amps to drive 1 sub since your amp is not designed to be able to run in mono or bridge mode.
However, what you can try is to reverse the + and - terminal.
The reason is that if the sub is place at a location where the wave cancels out the wave, it'll actually make the entire base go lower.
So sometimes reversing the polarity will have the enhanced effect.
Give that a try.
Also, you may want to consider using the main out rather than the subwoofer out as the sub out may have a filter build in that may actually get in the way of the signal.
Onkyo M-282... • Answered on Jan 23, 2011
This can be caused by a defective output power transistor, but a professional electronics technician is needed to test and confirm this.
Onkyo M-282... • Answered on Dec 27, 2010
your receiver must have a pre amp out on the back.
Onkyo M-282... • Answered on Aug 20, 2010
Hi...
If you try JUST headphones (spkrs off), does it still go into protect?
If so, I would say ( from my previous 50 or so receivers) that it needs new power supply capacitors
If not, either one of your spkrs is faulty or they arent connected solidly at both ends
If you dont have a manual, go to the Onkyo site
They have them there for download
Onkyo M-282... • Answered on Aug 19, 2010
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
Onkyo M-282... • Answered on May 24, 2010
I have exactly the same problem with exactly the same model. Any ideas anyone???
Onkyo M-282... • Answered on Feb 03, 2010
I would get the splitter that splits the jack from one to two rca jacks, then plug into both amp inputs and then run the speakers how you want. Make sure speakers on left side of room are on left channel and rights on right side otherwise it will sound weird. You have the right idea. You can get the splitters and anything else from amazon.com
Onkyo M-282... • Answered on Jan 10, 2010
called onkyo and kenwood they explained in detail how to hook up.
Onkyo M-282... • Answered on Jan 07, 2010
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Onkyo M-282... • Answered on Jan 01, 2010
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Onkyo M-282... • Answered on Oct 22, 2009
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Onkyo M-282 2-Channel Amplifier Logo
29 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Paul Bade
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo tx sv717pro amplifiier
  • Audio Players & Recorders
