20 Most Recent
Timex Atlantis 100 77511 Wrist Watch Questions & Answers
My Timex atlantis 100 displays 745007 and doesn't
I presume that you haven't got any instructions for your watch.
You can get instructions from the Timex web site "timex.com".
At
the bottom of the screen click on "manuals/downloads", then on "product
manual
download"
Enter your watch type in the search box and click on
"search"
What battery?
HI,
If you are looking to buy the battery for your timex watch then please click on the below link and contact their support number.They have batteries for Timex watches as well as they can help you get a replacement battery for your model too.You need to call them up and tell them that you need a battery for your model no. and they will help you fix this issue.
http://www.apexbattery.com/watch-batteries-timex-watch-batteries.htmlThank You
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads
timex.cahttps://www.timex.ca
Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers.
Rating for timex.ca: 3.7 - 209 reviews
- Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex
https://www.timex.ca > watch-manuals
Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz
https://manualzz.com > Fashion & style > Watches
View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
I Don't know to set up of the TIMEX DIGITAL WR100M IRONMAN CLASSIC 100 THAT I JUST GOT/// HELP
A lot of watch manufacturers use the American style date layout of Month/Day/Year. Try this. Looking at the watch press and hold the bottom right SIDE button for 3 seconds. It should enter setting mode where the seconds display will flash. Press the Right FACE button once. It should switch to the Hour display flashing. Press the same button again to go to minutes and them again to go to the date display.
Repeated pressing of the top Right SIDE button changes the numbers upwards, (1,2,3,4), and the Left FACE button changes the numbers downwards, (4,3,2,1). Press the Bottom right SIDE button once to finish and go back to the normal display.
http://assets.timex.com/manual/W-9.pdf
How to reset my timex 637 t5g951 wr 30 heart monitor
To reset your Timex 637 T5G951 WR 30 heart monitor, you can follow these steps:
- Press and hold the "Mode" button on the front of the watch for three seconds until the watch display shows "Settings."
- Press the "Next" button on the side of the watch to scroll through the settings menu until you reach "Reset."
- Press the "Mode" button to select "Reset." The display will show "Yes" and "No."
- Use the "Next" button to scroll to "Yes," and then press the "Mode" button to confirm.
- The watch will reset and return to the time display.
Note: Resetting your Timex 637 T5G951 WR 30 heart monitor will erase all your saved data and settings, so you will need to set it up again after the reset. If you need to keep your data, consider transferring it to another device before resetting the watch.
