20 Most Recent Onkyo TX-NR1000 Receiver Questions & Answers
Do you have standby light?If it is not,it is working like PC power supply.If itis notyou have a +13V AC problem (2 gray wire).Check this first.If you dont have it ,Give +13 DC to C9103.You will get standby light.
Onkyo TX-NR1000... | Answered on Apr 08, 2014
Try connecting your Onkyo directly to your modem first and see if you can use the internet radio. If it does, then we might need to change the settings of your router. Make sure you carefully follow the instructions on page 75 of the manual on how to listen to internet radio.
Onkyo TX-NR1000... | Answered on Sep 25, 2011
Depending on your TV and what input/outputs you have, you are almost always better off to run any video componenets through TV first then, audio out to receiver. In other words, run your HDMI out frim PS3 to TV then, digital optical out to receiver. If you have the capability to do so, you can run all you video componenets to TV, ie: sat/cable, DVD, etc., to TV with only one audio out to your receiver. You can use your TV's menu to select what you watch and you would only have the one audio out to receiver, you then just have to use the receivers menu to choose the proper channel to listen.
Onkyo TX-NR1000... | Answered on Aug 10, 2011
from the sound of it i would say your output tranny has gone ,open it up follow the circuit from the left output connection and see if its one big transistor with 7 legs or two seperate ones ,and change as necessary ,just clip old one out then solder to the stubs as you will need a special pump to **** the solder otherwise ,and you could damage something else with the heat trying to remove the old one ,this is not a difficult job to do as such providing your eyes are ok
Onkyo TX-NR1000... | Answered on Nov 18, 2010
Sure you can only connect 2 speakers. As for brand recommendation Polk audio makes some fine sounding speakers also Klipsch, Boston acoustics, too many to suggest. If you have a Best Buy near you they usually have a speaker room with many different brands that you can listen to. Though that doesn't mean you have to buy them their. I'm partial to Polk audio though. Polk has excellent customer service. That's going to be a tough decision you should really do some research on the internet for cost to quality references. Good luck. I hope this gets you pointed in the right direction.
Onkyo TX-NR1000... | Answered on Nov 24, 2009
my speakers call creative on my computer wont work they use to,i hear sound but not audible
Onkyo TX-NR1000... | Answered on Dec 24, 2007
Hi Madhu, I am a bit confused with your questions. If this has not been resolved for you please give us a call at 800-229-1687 as our Product Support Team is ready to assist 24/7, Thanks, JT
Onkyo Audio... | Answered on Jan 12, 2020
Your replacement remote (control) is not functionally equivalent to the other.
Onkyo Audio... | Answered on Jan 09, 2020
Check the equilibrium of speaker
Onkyo Audio... | Answered on Jan 04, 2020
See page 15 of the Manual (power transformer T901):
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Onkyo-DXC-380-Service-Manual.pdf
For British model see page 3 of the Manual (AC plug is fitted with a 5 amp fuse):
https://www.intl.onkyo.com/downloads/manuals/pdf/dx-c380_manual_e.pdf
Onkyo Audio... | Answered on Dec 16, 2019
Onkyo TX-NR1000 Receiver Logo
Popular Tags
15 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
audio suddenly died tx nr1000 but
  • Audio Players & Recorders
