20 Most Recent
2003 Chevy Astro - Passenger van, with factory roof rails - Base Rack System Questions & Answers
Thumping coming from rear end of chevy astro van
This could be a few things but always start with the basics (and cheapest). Check the tires for broken belts. If the tires are worn smooth, don't run your hand on them, you could get a sliver of steel belt in them (it hurts, trust me). If they aren't worn that much, run your hand over the tread and see if you feel any bumps.
If the tires seem ok, crawl under and grab the drive shaft. Make sure the van is parked on the level with no load on it (no weight on the parking pin...). If you can move it from side to side or there is play in it, it's probably the carrier bearing. It's not that expensive to fix by a mechanic ($150 roughly) or you could do it yourself with a basic socket set.
Mounting 250 Combibox on Land Rover factory rails
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
