20 Most Recent Onkyo TA-RW244 Single Cassette Deck Questions & Answers
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
5/19/2012 5:37:06 PM • Onkyo TA-RW244... • Answered on May 19, 2012
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
2/9/2009 11:07:18 AM • Onkyo TA-RW244... • Answered on Feb 09, 2009
I have an Onkyo SR-TX806 and it displays video from HDMI OUT but can't find a signal from HDMI IN
It sounds like you're experiencing an issue with the HDMI input on your Onkyo receiver. Here are a few things you can try to troubleshoot the issue: Check the HDMI cable - Make sure that the HDMI cable you're using to connect your video source to the receiver is properly plugged in and functioning. Try swapping the cable with a new one to see if that resolves the issue. Check the video source - Make sure that the video source (e.g. cable box, Blu-ray player) is turned on and properly configured to output video over HDMI. Also, try connecting a different video source to the HDMI input on the receiver to see if the problem is with the receiver or the video source. Reset the receiver - Try resetting the receiver to its factory settings. To do this, turn off the receiver, then press and hold the "VCR/DVR" button on the front panel of the receiver while pressing the "On/Standby" button. The receiver should display "Clear" on the front panel display. Release the "VCR/DVR" button and the receiver should reset to its factory settings. Check for firmware updates - Go to the Onkyo website and check if there are any firmware updates available for your receiver. If there are, download and install the update to see if it resolves the issue. If none of these steps resolve the issue, it may be a hardware problem with the HDMI input on the receiver. In this case, you may need to have the receiver serviced by a professional technician.
3/19/2023 1:58:17 AM • Onkyo Audio... • Answered on Mar 19, 2023
Hello Fixya team, I need help!
To set up your home theater system with the equipment you mentioned, follow these steps:
  1. Connect the Onkyo receiver to the NEC TV using an HDMI cable. Make sure the HDMI input on the TV is set to the correct input for the Onkyo receiver.
  2. Connect the Panasonic DVD player to the Onkyo receiver using an HDMI cable.
  3. Connect the Firestick Lite to the Onkyo receiver using an HDMI cable.
  4. Connect the Panasonic speakers to the Onkyo receiver using speaker wires. Make sure you connect the speakers to the correct speaker terminals on the receiver, which are usually labeled with the speaker's position (e.g. front left, front right, center, surround left, surround right).
  5. Configure the Onkyo receiver to use the correct input for each device. For example, set the input to "DVD" when you want to watch a movie on the Panasonic DVD player, or set the input to "Firestick" when you want to watch content on the Firestick Lite.
  6. Configure the audio settings on the Onkyo receiver to use the correct audio format for your content. For example, if you are watching a movie with Dolby Digital surround sound, make sure the receiver is set to decode Dolby Digital audio.
  7. Adjust the volume and other audio settings on the Onkyo receiver as needed to optimize the sound quality.
Once you have completed these steps, you should be able to enjoy surround sound audio from your Panasonic speakers through the Onkyo receiver.
3/15/2023 12:22:26 PM • Onkyo Audio... • Answered on Mar 15, 2023
2answers
Onkyo HT-R550 front panel Display doesn't work.
I don’t have access to schematic for HTR550 but I do for HTR500 and it will be very similar. The components of interest are in the display board, primarily the electrolytic capacitors, it has likely failed. The screen brightness voltage comes in as ac to the screen board then goes through the circled area in the picture below, the likely failure is as said the electrolytic capacitor or could be dry solder joints. Burnt resistor will always be permanent and not intermittent. It could also be the -VP line causing the fault but this is less likely.
2/27/2023 11:36:01 AM • Onkyo Audio... • Answered on Feb 27, 2023
Lost surround Onkyo sr 60.1
It sounds like there may be an issue with the amplifier or the speaker wire. The fact that the channel has come back after reconnecting the speaker wire in the past suggests that the problem may be with the wire itself. However, the fact that the cat has chewed on the wire may have caused damage to it, which could be causing the current issue. It could also be an issue with the amplifier, such as a burn out on the right surround channel. To determine the cause of the problem and whether it is worth fixing, it would be best to take the amplifier to a professional for diagnosis and repair. The cost of the repair will depend on the specific issue that is causing the problem.
1/17/2023 4:52:45 AM • Onkyo Audio... • Answered on Jan 17, 2023
Remote control for Onkyo TX-8511
look on eBay or amazon
1/1/2023 8:17:28 PM • Onkyo Audio... • Answered on Jan 01, 2023
Onkyo receiver long delay in audio after starting
This might be a problem in the power supply section. It could be the big Capacitors in that section. Slow to charge up.
12/18/2022 12:53:33 AM • Onkyo Audio... • Answered on Dec 18, 2022
Onkyo TXNR-807 eARC issues
If you're having trouble getting sound from your TV, there are a few things you can check to try and troubleshoot the issue. First, double-check all the connections between your TV and receiver. Make sure they are secure and that you're using the correct inputs. Next, take a look at your TV's settings. Make sure eARC is enabled and that the TV is outputting sound through the correct port. If you're not sure how to do this, consult your TV's manual. Similarly, check your receiver's settings to make sure eARC is enabled and that it is set to the correct input. Again, consult your receiver's manual if you're not sure how to do this. If you're still having trouble, try resetting your receiver. This can often fix audio issues. Hopefully one of these tips will help you get the sound from your TV working properly.
11/22/2022 3:19:28 PM • Onkyo Audio... • Answered on Nov 22, 2022
Onkyo tx-ds838 surround amp fuse replacement 125v 6.3a tsc fuse same as fast acting 6a?
That is an INRUSH rated so it is a slow acting fuse
11/7/2022 1:35:24 AM • Onkyo Audio... • Answered on Nov 07, 2022
2answers
How to connect Onkyo receiver tx8211 to new style speakers
The Onkyo receiver is designed to use 2-wire speaker wires. Amazon has adapter cables. This one is for use with M/M RCA audio cables: https://www.amazon.com/Speaker-Wire-Stereo-RCA-Adapter/dp/B076P7KP3D . You'll need one pair per speaker. This one, https://www.amazon.com/Speaker-18AWG-Adapter-Cable-UIInosoo/dp/B097XV7QNL/ref=pd_lpo_3?pd_rd_w=ZUie5&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=1DWE6KY3W0JYFQT74WZT&pd_rd_wg=QGafl&pd_rd_r=b6c31a62-2ae3-406f-9e66-6333f7edbf7b&pd_rd_i=B097XV7QNL&psc=1 , is for a direct connection to a RCA F connection on the speaker. I hope this helps. Cindy Wells
10/29/2022 1:49:30 AM • Onkyo Audio... • Answered on Oct 29, 2022
I have no sound output on my Onkyo TX-SR605. No rear connections work although Zone 2 does. Any ideas?
Hi ,try factory reset your unit if that dosent help its pobobly your digital board gone bed, try contacting your local service for mo information.
10/6/2022 11:12:26 PM • Onkyo Audio... • Answered on Oct 06, 2022
ONKYO AV Receiver - model is HT-S3910 (B)
Hi,the letters after NG refer to the affected channels - left center, right surround, etc. Do you have speakers plugged into these channels? If yes try to unplage all speakers then plage one speaker at a time,check your speakers if that dosent work for you try to factory rest your unit .
10/6/2022 11:08:55 PM • Onkyo Audio... • Answered on Oct 06, 2022
Does my onkyo cr 325 reciever have bluetooth capabilities?
Nope. https://www.manualslib.com/manual/115270/Onkyo-Cr-325.html?page=7#manual
9/24/2022 3:27:09 AM • Onkyo Audio... • Answered on Sep 24, 2022
My Onkyo quartz synthesized tuner amplifier tx-903 is stuck on stand-by the power button will turn it off and on but it won't leave stand-by mode
Have you tried unplugging it? If you have and it still doesn't work try resetting it, you can look up how to reset it, on google, i've had to do this before
9/1/2022 2:25:39 AM • Onkyo Audio... • Answered on Sep 01, 2022
2answers
I have a onkyo av receiver Tx-sr309 that is stuck on BD/DVD mode and no other keys/buttons on the receiver nor the remote functions. Not possible to do factory reset as well. Kindly help
‘I have a onkyo av receiver Tx-sr309 that is stuck on BD/DVD mode and no other keys/buttons on the receiver nor the remote functions. Not possible to do factory reset as well. Kindly help’ Of course, no reset is allowed due to single task MPU.This is a very easy issue to fix and a common faulty situation found in onkyo AV-amp. If you want to know how to fix, just send an email to me if you want. It is up to you to do so and email will be deleted after ONE week. I won‘t tell you here due to buying faulty AV amps to repair and sell them out on web.
8/13/2022 1:40:51 PM • Onkyo Audio... • Answered on Aug 13, 2022
Onkyo T-4530 tuner not keeping stations
well there are only 3. ways. 1: battery + NvRAM<< a coin cell seen any sized even soldered. 2: eeprom chip (look MA/ no battery ever. (pure joy) 3: supercap _+ NVRAM what is there only takes looking if no battery and no FARAD HUGE super cam then it is #2 the super cap is the only huge cap there marked FARADS and not marked uF. not microfarads easy no, 3 classes of storage for 40 years.
8/2/2022 7:09:35 PM • Onkyo Audio... • Answered on Aug 02, 2022
Onkyo TA-RW244 Single Cassette Deck Logo
3 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
gunk fused record playback heads onkyo
  • Audio Players & Recorders
