20 Most Recent Tour Trek One Click Deluxe 4 Wheel Collapsible Push Cart Questions & Answers
You need a new battery then. Or look at the wires. Do they all connect?
Golf | Answered 2 days ago
Firstly is never add water to a discharged battery as the level will rise during charging. If the battery overflows, the sulphuric acid electrolyte causes the sort of corrosion it is difficult to stop or get rid of...
Heat generated during charge/discharge and natural evaporation causes some evaporation and adding a little (preferably) distilled water to a fully charged battery
If the battery electrolyte has been allowed to fall so much a cell appears dry, begin the recharging process on a low current checking the electrolyte level every few hours; if after around 12 hours the plates still appear dry add about an egg-cupful of water and repeat...
Eventually the electrolyte level will be correct - either a quarter to a half inch above the plates depending on the size of the battery or if there is an indicator, level with it. Once the electrolyte level is correct and it has been on charge for a few hours and then allowed to stand until cool the state of charge and battery condition should be checked with a hydrometer.
A healthy battery has each cell with a similar hydrometer reading within a very small margin and is close to the gravity of the original fill, typically 1250/1260.
Golf | Answered on Nov 15, 2020
It isn't unusual for a fuel haze to hover outside the carb of a high performance engine but a golf cart engine is definitely not that.
A more detailed description would have been helpful.
On the face of things, it suggests the piston is rising on the compression stroke while the intake valve is still open but slipped timing is very unlikely.
The only other time when fuel is commonly blown from a carb is when the engine kicks back during starting and will spin backwards a revolution or two. Over-advanced ignition timing or a lean air/fuel mixture can cause this.
If it was ok before the new carb it would be a good idea to revisit that fitment, comparing the settings with the original...
Ask these people
E-Z-GO - Legend - Western - Vintage Golf Cart Parts Inc.
www.vintagegolfcartparts.com > Category > ezgo
Welcome to our E-Z-GO - Legend - Western Catalog. The carts above listed from left to right are first a red mid 1950s E-Z-GO, one of the first, next a green ... ‎Engines & Exhaust - ‎Body, Trim & Seats - ‎Ignition - ‎Manuals & Publications
Golf | Answered on Nov 05, 2020
I don't know the answer but usually the steering track rods are adjustable even on the most basic of vehicles.
If due to neglect on the part of the designer the track rods aren't adjustable, some part of the suspension/steering must be adjustable - suspension arms for instance.
If there genuinely is no provision for adjustment (that is difficult to imagine) and the alignment is incorrect - the words of my college tutor come to mind, "if all else fails, use the body jack to twist things until the alignment is correct".
Golf | Answered on Nov 04, 2020
Corrosion by break pedal. Clean and lubricate
Golf | Answered on Nov 01, 2020
Here is a download of the service manual. Page 11-1 has a schematic showing where the fuses are.
https://rmigolfcarts.files.wordpress.com/2010/09/yamahag22eowners.pdf
Golf | Answered on Sep 14, 2020
I have same problem with my ruff and tuff. I bought brand new batteries and will not charge.
Here Are Our Top 9 Best Golf Push Carts (And Reviews) For 2020:
  • Clicgear Model 3.5+ Golf Push Cart.
  • Bag Boy Quad XL Golf Push Cart.
  • Paragon Push Cart.
  • Spin it Golf Push Cart.
  • CaddyTek Superlite Explorer.
  • Bag Boy Express DLX Pro Golf Push Cart.
  • Tangkula Golf Push Cart.
  • Pinemeadow Golf Courier Cruiser.
https://honestgolfers.com/best-golf-push-carts-review/
Golf | Answered on Mar 27, 2020
Apparently a Golfsmith brand. See link below for telephone and online chat to request assistance from a vendor.
https://www.golfgalaxy.com/?acq=Golfsmith
Golf | Answered on Mar 26, 2020
As the bodywork is mainly grp make sure the indicator lights are grounded (earthed). This may require a ground wire from each indicator light back to the chassis or wherever the battery is grounded
Golf | Answered on Nov 10, 2019
Golf buggy bodies are normally grp. Make sure the indicator light units are grounded (earthed ) by running a wire back to the chassis
Tour Trek One Click Deluxe 4 Wheel Collapsible Push Cart Logo
2 questions posted
Top Tour Trek Golf Experts
ray gallant
Kardoc
Bill Boyd
Are you a Tour Trek Golf Expert? Answer questions, earn points and help others
View Most Popular
Tour Trek Golf
  • Tour Trek Golf
Most Popular Question
in toronto area or line get parts 4
  • Golf
