20 Most Recent
Graco iMonitor Vibe Baby Monitor 2M16 Questions & Answers
On one of our two parent receivers, it's showing 1
I had the same thing happen to one of my parent units over the weekend. The issue is that the parent unit lost the pairing with the nursery unit. Once I re-paired them, it's working great again. This is in the Troubleshooting part of the manual, but I've copied below for your convenience.
If Parent Unit won't lock onto the Nursery Unit, or you purchased a new Nursery Unit, follow the procedure below to pair the Parent Unit and Nursery Unit. If you purchased a new Parent Unit, skip Step 1. The new Parent Unit is ready to pair with your Nursery Unit.
1. Erase the Pairing from the Parent Unit.
Turn the Parent Unit off.
Hold the Volume Down Button on the Parent Unit while
pressing the On/Off Button. Continue to hold the Volume
Down Button until you hear a single beep and all of the
Sound Lights illuminate briefly.
Release the Volume Down Button.
Press and hold the Volume Down Button again.
Within 2 seconds you will hear a beep. Release the Volume
Down Button. All of the SoundLights and the red Loss
Connection LED will be lit. The Parent Unit is ready to pair
with Nursery Unit.
2. Pair the Parent Unit with Nursery.
Place Nursery Unit in the same room, five (5) feet
(1.5 meters) away from the Parent Unit.
Turn on Nursery Unit using the On/Off Button on the side.
The green power light should come on.
Within a few seconds, the Parent Unit will find the Nursery
Unit. The SoundLights will shut off and the Parent Unit will
beep. The Parent Unit is now paired with Nursery Unit.
3. Repeat this procedure if you need to pair another
Parent Unit with the Nursery Unit.
Nothing happened when I turned on the Nursery Unit.
What do I do?
First try turning the Nursery Unit off, and then on again.
If the Parent Unit still does not pair with the Nursery Unit,
press the Channel Button on the Nursery Unit, then turn the
Hope this helps.
How do you remove canopy from graco sweetpeace
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
How to remove seat wire, after putting it in wrong on the Graco uno2duo stroller?
This question was posted a long time ago, but no one answered it correctly. If you put the wire in backward, look on the end of where the wire was inserted. You made have to move the fabric to see it. There are holes. Use something to push in the metal piece that is showing as you pull out each side of the wire. I used a house key to push in the button while I removed the wire.
