20 Most Recent
GE SteelBEAM FluorescentLED Hybrid Lantern Black Questions & Answers
How to replace blub in ge lantern
Bulb went off suddenly, put new batteries in, still didn't work. Took pliers and unscewed to four posts by the globe, popped it off, twisted the bulb and it came on. Tried to unscrew it, but was too secure in the lamp, but at least I got the dam thing to work again.
I have a GE battery
Fluorescent lamps need a high voltage in order to ionise the gas inside and make them light up..Torch batteries will not produce enough voltage alone so the battery voltage is boosted by an inverter that is incorporated into the torch or lamp body.
It is unfortunate but the majority of such lamp inverters use the cheapest, nastiest, flimsiest circuitry it is possible to use in such things and having taken a few lamps and torches (of respectable brands) apart and seen such things I find it easy to imagine they were thrown together in a far eastern handbag factory when there was a world slump in handbag sales.
When working correctly the inverter produces a voltage high enough to really surprise anyone touching the wrong parts but they do tend to be unreliable due to the usually low quality.
A handy person could conceivably persuade such a lantern to dismantle and check the switch and wiring and ensure the battery voltage is reaching the inverter but it would need electronic experiece to venture further into the reasons why it stopped working.
A replacement tube could be tried but they fail rarely and rarely do they operate long enough to actually wear out so buying a new tube is likely to be wasted money.
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
- Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
- Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
- Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
- Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
- Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
- Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM •
Camping,...
Answered
on Apr 16, 2024
