20 Most Recent
Maxi-Cosi Loola Stroller Questions & Answers
Spare parts
Hi KarenIf you're in the UK and your Loola is under 2 years old please contact your retailer with proof of purchase for them to send it in for our engineers to provide inspection & repair under warranty terms and conditions.If you're in the UK and your Loola is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to book in for chargeable inspection and repair work required. Standard cost is 39.99GBP and this will include courier collection and delivery for the item.If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the "Contact Us" tab for your enquiry to be sent through to the customer care team who can best assist you.
The button on the left handle does not click out?
HiIt needs to be sent in for inspection and repair work required.
If you're
in the UK
and the product is under 2 years old, please contact your retailer with your
proof of purchase and they can arrange for it to be sent to our engineers for
inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have
Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking
it in for chargeable inspection / repair work required.
If you're
outside the UK
country you're in, then use the "Contact Us" tab on the right side for your
enquiry to be sent through to the customer care team in your country.
I have the bebe confort
If the wheel is remaining locked it indicates the wire is broken or has come off the necessary componant within the handlebar.If the Loola is under 2 years old return to your retailer with proof of purchase for them to send to the engineers for inspection/repair work required under warranty terms and conditions. If it is over 2 years old or you do not have proof of purchase contact 01284 413 141 Mon-Fri 8.30-4.30 to book it in for chargeable repair. Standard cost is 72GBP and includes courier collection and delivery.
How do i take the brake wheel/housing off a loola.
Good Afternoon
Due to the safety implications of this being incorrectly re-fitted it is not advised that customers attempt to carry out repair work.
In the instance of repair work when the unit is under 2 years old please contact your retailer with your proof of purchase.
In the instance of repair work when the unit is over 2 years old or you do not have proof of purchase please go to
www.maxi-cosi.com and select the country you're in, then go to the "Contact Us" tab to be put in touch with the customer service department in your country for further advice.
Brakes are slipping and handles dont click in
Good Afternoon
Are you a UK customer?
If you are, and the product is under 2 years old, please contact your retailer with proof of purchase for them to send the product to our engineers for full inspection & any repair work required under the terms and conditions of the warranty.
If you are a UK customer but the product is over 2 years old or you no longer have your proof of purchase please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to book it in for chargeable inspection and repair work required. Standard charge is £60 and this will include courier delivery service of the unit back to your address; in addition you will need to make arrangements and cover costs for the product to be sent by courier into our engineers.
If you're not a UK customer please visit
www.maxi-cosi.com and select the country you're in and use the "contact us" tab to get in touch with the customer service department in your area.
Repair broken wire on Maxi-Cosi 2wayfix base.
Hello
In some countries Maxi-Cosi do have service centres where inspection & repair is possible. You should contact your local Maxi-Cosi office (Facebook or via Maxi-Cosi website, "Contact Us" option) They will be able to advise you.
The car seat I have
Hi
Maxi-Cosi do not produce the adapters for the carseat to be used with Mamas & Papas chassis. Adapters would be designed, tested, approved and sold from Mamas & Papas. If the adapters do not fit the carseat they need to investigate this for you. The CabrioFix carseat is only one model and regardless of date of manufacture all Maxi-Cosi adapters for CabrioFix are the same. (For using Maxi-Cosi carseat on Maxi-Cosi pushchair chassis)
The spring has come apart on the maxi-cosi family fix base
The unit will need inspection / repair.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 08:30-17:30 / Fri 08:30-16:30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit
www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
How can I get the footrest to stay in the 'up' position?
Hi
