20 Most Recent
Bosch 1973 - 1975 Mercedes-Benz 450SL Fuel Injection Pressure Regulator Bos Questions & Answers
Bought an 8201-cl Skil Laser Line Level and can't
Yes, you have to measure up from the line it gives you. It gives you a precise level so mark it and then measure up (or down) from it.
Or place the tripod on a table or something to get to higher position.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
