20 Most Recent
Vizio L6 20.1 in. HD-Ready LCD Television Questions & Answers
Check and replace the main digital board. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Vizio L6 20.1...
Answered
on Oct 28, 2013
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Vizio L6 20.1...
Answered
on Aug 10, 2013
Call Vizio with the model number but I suspect it is related to main board or power supply.
Vizio L6 20.1...
Answered
on Jun 07, 2012
The solution is hold down the input button on the tv. The tv went into RGB mode wich makes it a computer monitor. This is a really common problem with vizios and there is now way to disable this
Vizio L6 20.1...
Answered
on Oct 30, 2011
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Vizio L6 20.1...
Answered
on Jun 06, 2011
If you cleaned it with windex or water this Probably what made it have the white smear mines has it aswell and it's annoying
Vizio L6 20.1...
Answered
on Mar 30, 2011
You mean how to get the sound from DVD player to the TV.
Make and model of the DVD player?
Please tell us what you have first.
Vizio L6 20.1...
Answered
on Jan 29, 2011
Hi
Thanks for using FixYa. From what
you have described it seems the issue is with the power board or the main board
and we’ll need to check few things. When you open the unit up; take a look at
the power board-the board where the power cords/plugs goes into. You might see
some filter capacitors a little bulged up in the top-If this is the case-this
is your defective part(you can try to replace them-but some soldering equipment
is needed). If not, then probably the main board has gone bad. This is the other
board-where all the inputs are going into. All this is only recommended if you
have electrical expertise and know how to solder/re-solder components. Please
note that the TV components consists high voltages even when in off position. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
Vizio L6 20.1...
Answered
on Apr 13, 2010
change the sustainer boards will fix this problem
Vizio L6 20.1...
Answered
on Jun 16, 2009
its a video cable or LCD connectors. remove and re-connect again.
Vizio L6 20.1...
Answered
on May 27, 2009
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Vizio L6 20.1...
Answered
on May 06, 2009
my 50 inch vizio plasma bulb went out...still turns on with sound ..but no picture...help
Vizio L6 20.1...
Answered
on Apr 13, 2009
Check to see if you have the audio in SAP mode ! If it is turn it off, or to stereo.
Vizio L6 20.1...
Answered
on Mar 29, 2009
Vizio L6 20.1...
Answered
on Mar 20, 2009
Mine does the same thing and it works fine. It may be using any remaining power to shut completely down.
Vizio L6 20.1...
Answered
on Feb 27, 2009
Hi
phalbeis,
Unfortunately it looks like the power supply has failed, since the unit is new I would check into the return policy of the store you bought it from, if your lucky you can just exchange it. If not it will have to be shipped back to the manufacturer.which can be a hassle, you may have to pay the shipping to the repair
facility.
Let me know how it goes and please rate this solution.
Lone99star Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/jason_77a19afa8d604dee
Vizio L6 20.1...
Answered
on Jan 21, 2009
