20 Most Recent Liebherr Premium K 2954 Top Freezer Refrigerator Questions & Answers
Freezer not freezing, or if it is lettuce etc in fridge freezes
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
2/8/2010 2:50:47 PM • Liebherr Premium... • Answered on Feb 08, 2010
Liebherr cnesf 5013 superfrost always beeping
Maybe it is only in the settings, I don't know the details of your ref but I would like to suggest to consult it in the technical experts.... because you said, it is turning on and off but it is working, maybe you only mistakenly click some button but if not, the refrigerator is the problem ( if it is new one, you can return it and replace a new refrigerator but in this case, you need to check it before replacing another one)
10/29/2021 4:02:51 PM • Liebherr... • Answered on Oct 29, 2021
My Liebherr premium freezer keeps dropping temperature.
call a local repair service
6/16/2021 12:29:20 AM • Liebherr... • Answered on Jun 16, 2021
My integrated Liebherr brand new fridge/freezer is making a clicking sound? Fan? It’s not the alarm
then you have the dealer send out the tech to fix it we do not try to fix NEW things warranty work
5/29/2021 8:48:19 AM • Liebherr... • Answered on May 29, 2021
I have a Liebherr fridge CS 2062. Both doors gaskets need to be replaced. What are the part#s and where to order? Thanks
That's not the way it works. Normally you contact a company and say "I want door gaskets for a Liebherr CS 2062". Let them worry about part numbers. They are here https://www.letstalkparts.com/Liebherr-Appliance-Parts-s/283.htm https://www.google.com/search?q=Liebherr+fridge+CS+2062.+doors+gaskets ..
4/7/2021 9:01:40 PM • Liebherr... • Answered on Apr 07, 2021
Liebherr fridge stops working after 1 hour.
The Spaminator Mar 22, 2021 Hi Jasmin Black, I suspect ice build up behind the back panel of the freezer could be causing this. this could be due to a faulty thermostat transducer that tells the freezer to defrost when the ice builds up.
3/22/2021 10:25:01 AM • Liebherr... • Answered on Mar 22, 2021
Model CN4003-21. Why doesn't the refrigerator part cool?
first check the freezer compartment temperature
12/4/2020 7:32:47 PM • Liebherr... • Answered on Dec 04, 2020
Liebherr C1650 Refrigerator Ice Cube Maker Problem: making cubes but also spilling excess water.
Descale it. Clean it with a brush. check the inlet is clean. Check the drain is clear. However, it is a known issue. Advice here https://www.houzz.com/discussions/2333121/liebherr-36-icemaker-problems Page 20 http://assi.lhg.liebherr.com/Serviceline/b2b/bab2b/Media/Documents/BA/708248101_gb.pdf ..
11/29/2020 7:46:00 PM • Liebherr... • Answered on Nov 29, 2020
Why Liebherr CS 1651 freezer temperature keep flashing
snelvrieser aan of temp onder 16 gr
8/19/2020 6:21:07 PM • Liebherr... • Answered on Aug 19, 2020
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
6/25/2019 11:45:28 AM • Liebherr... • Answered on Jun 25, 2019
Liebherr Premium K 2954 Top Freezer Refrigerator Logo
Popular Tags
3 questions posted
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
freezer not freezing or lettuce etc in
  • Refrigerators
