20 Most Recent Liebherr K3660-20 Refrigerator Questions & Answers
Frozen Liebherr Refrigerator - 3 yrs old
Defrost heater element is open and the defrost mechanism is not working. replace the part here Search Over 2 1 Million Appliance Parts
9/3/2017 11:55:08 AM • Liebherr... • Answered on Sep 03, 2017
0answers
0answers
0answers
0answers
Hello My Liebherr K 36600 freezes
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
9/20/2011 8:49:17 PM • Liebherr... • Answered on Sep 20, 2011
Everything in the fridge is becoming almost frozen
The thermostat section of the control board is either set on the highest setting - at 0C or even slightly below it - or it's faulty. Set it to the lowest setting - the highest temperature available - and see what is happening: if you get the same result then either the temperature sensor or the control board are defective and they will have to be replaced by a certified repairman - you will have to call one.
4/13/2011 8:42:45 AM • Liebherr... • Answered on Apr 13, 2011
Fridge acting like a freezer - with no difference
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
3/6/2011 6:23:49 PM • Liebherr... • Answered on Mar 06, 2011
Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
11/3/2010 1:36:33 PM • Liebherr... • Answered on Nov 03, 2010
Lamp flashing on and off with apparent drop in
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
8/28/2010 12:53:18 PM • Liebherr... • Answered on Aug 28, 2010
Food is freezing -has thermostat gone?
yes
3/27/2010 12:21:10 PM • Liebherr... • Answered on Mar 27, 2010
Liebherr fridge model CS1231. How to turn off demo mode on it please?
DemoMode
Liebherr Appliances https://home.liebherr.com > hau > apac > pdf PDF Demo Mode can only be switched off via the service menu, not by pressing ON/OFF nor by disconnecting the appliance from the mains. Once "SuperFrost" has been ... 20 pages
8/7/2023 11:00:09 PM • Liebherr... • Answered on Aug 07, 2023
2answers
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM • Liebherr... • Answered on Apr 05, 2023
2answers
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker. Question moved to maker category. Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear. Push a flexible net curtain wire down the drain until it appears above the compressor pan. You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking. https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560 ..
3/29/2023 5:02:00 PM • Liebherr... • Answered on Mar 29, 2023
Liebherr CUN 3033 The super frost button flashes together with the temperature display. how to reset it?
Resetting your Liebherr CUN 3033 is a fairly simple process. To begin, make sure the appliance is unplugged from the power outlet. Once this is done, press and hold the super frost button for roughly 10 seconds. The appliance should then be reset and ready to use.
1/18/2023 5:44:12 PM • Liebherr... • Answered on Jan 18, 2023
Short power outage confuses Liebherr CbNes 39560 temperature regulation
Unplug it from the mains for 5 minutes to reset the main control board. It is confused by a short disconnect and more confused as it went through its self test procedure. https://www.google.com/search?q=Liebherr+CbNes+39560+reset ..
7/22/2022 1:38:01 PM • Liebherr... • Answered on Jul 22, 2022
Liebherr K3660-20 Refrigerator Logo
Popular Tags
19 questions posted
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Paul Carew
Daniel Blask
Daniel Blask
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
frozen liebherr refrigerator 3 yrs old
  • Refrigerators
