20 Most Recent Razor USA Razor Pocket Mod Electric Scooter Questions & Answers
Do you own a multimeter to check the voltage output from the battery
Razor USA Razor... | Answered on Sep 01, 2014
one or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
Razor USA Razor... | Answered on Jun 25, 2013
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Razor USA Razor... | Answered on Jun 26, 2012
there isn't one, but there are fuses by the battery that can be replaced
Razor USA Razor... | Answered on Jun 12, 2012
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
at least 24 volts, usually a little more
Razor USA Razor... | Answered on May 23, 2012
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
under the seat you have to remove the screws that hold the compartment on then this will give you access to the batteries and the fuse
Razor USA Razor... | Answered on May 22, 2012
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
Razor USA Razor... | Answered on May 01, 2012
I just bought these at a yard sale today. Did anyone find an answer to this or know what the name of the toy is? Manufacturer?
Toys | Answered on Jun 27, 2020
Of course not .only thru the bank can pin,s be reset
Razor USA Razor Pocket Mod Electric Scooter Logo
30 questions posted
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
View Most Popular
Razor USA Toys
  • Razor USA Toys
Most Popular Question
reset button razor bella scotter
  • Toys
