20 Most Recent Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (55 lb Thrust 54 Shaft) Questions & Answers
I have a minn kota
Bring a couple of paddles when you use that little pup
11/2/2017 10:46:10 PM • Minn Kota... • Answered on Nov 02, 2017
Speed is stuck wide open
home These guys will tell you what is wrong and sell you the parts to fix it!!
7/6/2017 3:28:17 AM • Minn Kota... • Answered on Jul 06, 2017
I have a 2006 Lowe
Hey 217, Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush. You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
7/6/2017 3:25:00 AM • Minn Kota... • Answered on Jul 06, 2017
Is there any way to install an aftermarket transducer to minnkota powerdrive v2
is it a built in ducer or mounted if built in no got to have that ducer
12/19/2013 11:30:31 PM • Minn Kota... • Answered on Dec 19, 2013
0answers
0answers
I got a minn kota power drive its 24v and i dont
in series
5/23/2011 7:51:36 PM • Minn Kota... • Answered on May 23, 2011
The wrong user manual was
Not sure of the exact model for yours, but here is a link to a website with a few free manuals: http://www.minnkota.com.au/support/user-manuals/motor-manuals/powerdrive-v2.html
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated. Once there click on the link to your model and then you will see contents of that Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there. Good luck.
3/24/2011 4:25:13 PM • Minn Kota... • Answered on Mar 24, 2011
We have a Minn Kota riptide 55. Serial WWAI12730357. Used once when new and has been sitting since. We need a manual.How do we go about getting same.
Hi. Based on the serial number provided, your Riptide PowerDrive would be a 2008 Weedless Wedge model. You can download the product manual at the following link: https://johnsonoutdoors.widen.net/content/myx2vf5heb/pdf/min_productmanual_rtsp-55-om.pdf
1/15/2024 11:14:38 PM • Minn Kota... • Answered on Jan 15, 2024
I left my minn Kota I pilot turn on will this be harmfull
Hi. I believe you are referring to a Minn Kota with i-Pilot GPS? If you forget to turn the power button off and the motor was not running (meaning the prop was not turning), your motor should be fine. Ultimately, if left on for long enough, it will drain the batteries and eventually turn off. This is not harmful for the motor. For safety reasons (yourself and others), it's always best to disconnect the motor from the power source when not in use.
1/14/2024 10:12:39 PM • Minn Kota... • Answered on Jan 14, 2024
Minn Kota DeckHand 18 won't run
Did you check the breaker and fuse. The strain of a rope foul would trip the breaker. Page 18 shows breaker in circuit for the DH15 - DH25 https://productimageserver.com/literature/ownersManual/36957OM.pdf
Fuse or circuit protector ' Boating Forum
iBoats https://forums.iboats.com > threads > fuse-or-circuit-pr... Mar 9, 2021 - I just purchased 2 Minn Kota DeckHand 40 anchor winches. They have built in circuit breakers, but should I also run fuses to them as well? You would need to strip it and test the motor. You can still get parts by the look of it. https://www.google.com/search?q=Minn+Kota+DeckHand+18 ..
7/31/2023 11:27:48 PM • Minn Kota... • Answered on Jul 31, 2023
Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (55 lb Thrust 54 Shaft) Logo
30 questions posted
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota Boating
  • Minn Kota Boating
Most Popular Question
wrong user manual
  • Boating
