20 Most Recent Lowrance Hds 5 Hds5 Fishfinder gps Chart Plotter Questions & Answers
Got you covered.
Here is the link to your owners manual.
Hope this helps.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/CA/HDS-5-7-5M-7M_OM_EN_988-10041-001_w.pdf
Lowrance Hds 5... | Answered on Feb 27, 2015
First try to clean the interior, removing all the contact spray. It will cause the metal parts to oxidise If you see oxidised parts or contacts, try cleaning those parts. Also check if the contacts of your cabling are still free of dirt and oxide.
Take care don't clean with sharp tools, because toy will damage the contacts, bend repair.
Success
Lowrance Hds 5... | Answered on Jul 17, 2014
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Lowrance Hds 5... | Answered on Jul 19, 2012
It is an entry level fish finder. It doesn't have GPS tracking which is used these days to mark distance traveled against time to display the speed. 'Old fish finders had a wheel on the transducer (yours doesn't), and nothing in the manual leads me to believe that your unit displays speed. The only measure of speed is in relation to how fast the chart speed is. I am a Humminbird person, but that is what I see after studying the unit.
https://www.manualslib.com/manual/524521/Lowrance-Elite-5x.html?page=24#manual
https://www.fishfinderreviews.net/lowrance-elite-5x-review/
Lowrance Boating | Answered on Feb 25, 2020
Contact Lowrance directly to inquire.
Lowrance Boating | Answered on Dec 25, 2019
A transducer does not give "colors".. the unit its plugged into provides the colors..
50khz for deep water.. 200khz for shallow water..
A transducer simply sends and receives signals to and from whatever is on the bottom of the lake...
Lowrance Boating | Answered on Dec 15, 2019
For deep water you will want to run the lowest hertz setting. For example, if you have the option for 80hZ or 600hZ, then the 80hZ would be for deep water and the 600hZ would be for shallow water.
Lowrance Boating | Answered on Oct 03, 2019
Reset use a soft reboot. Or hard reset make sure you back up all your settings on fish finder with chip or home computer. OK guys so the first thing you wanna do when resetting your unit whether it's soft reset or hard reset we're gonna start with a soft reset which is gonna save any GPS data anything like that so we're gonna head over hold the Power & Page button press the power button we're going to go over and press power button but I'm at the unit but up until you see the warning screen where you have to except the depth on reset Can see we still have our Saved waypoints. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power switch to off then press and hold the plus minus key as well as the power key let go of the power key keep holding plus minus until the warning screen comes up in a hard reset your going to delete all data on this year it's gonna be like we just bought it went to the store and bought it and cam home with know data whatsoever no settings nothing OK I warning screen has came up we can let go of her buttons and press except start demo. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power so that our unit is off then press and hold the plus & minus key as well as the power key don't let go with the power key holder plus minus until the warning screen comes up and a hard reset is going to delete all data on this year it's gonna be like-you just bought it went to the store and bought it and brought it home no data whatsoever no settings nothing OK or warning screen has came up we can let go over buttons and press except start demo now. OK so now you should not see any saved data so that's how you do a hard reset and a self reset. Load your Data card and shut off the power key. Then turn back on and follow screen steps. This should fix you issues.
Walld"
Lowrance Boating | Answered on Oct 02, 2019
Contact Lowrance directly to purchase.
Lowrance Boating | Answered on Sep 17, 2019
Contact supplier for support and possibly replacement for a faulty unit.
Lowrance Boating | Answered on Jul 31, 2019
Make sure the transducer is pointing directly down when the boat is in the water. Also, this may help
Lowrance Boating | Answered on Jul 03, 2019
Need to contact the manufacturer for support on this. It may not be fixable.
Lowrance Boating | Answered on Jun 10, 2019
Probably time for a new one. Harsh conditions like on a boat causes the electronics to fail after awhile
Lowrance Boating | Answered on Jun 05, 2019
Check the Positive and negitive terminals It may not be seeing the voltage it needs , I have a strike 7 and it did a similar thing , as soon as the load from the transducer is on it wont load ,, Mine was the dirty Neg cable to the bus bar under the dash
Lowrance Boating | Answered on Apr 24, 2019
Lowrance Hds 5 Hds5 Fishfinder gps Chart Plotter Logo
Popular Tags
6 questions posted
Top Lowrance Boating Experts
Ekse
Mike
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
change screen gps 0n hds5
  • Boating
